As a new user of NVIDIA DRIVE Platform I am trying to execute basic driveworks samples. Sadly I am struggling with this since I always get the same error for any sample I try to execute in usr/local/driveworks-0.6/bin/ :
& ./sample_drivenet
./sample_drivenet: error while loading shared libraries: libcuda.so.1: cannot open shared object file: No such file or directory
Following this I found libcuda.so.1 in /home//NVIDIA/Drive/5050aL_SDK/DriveSDK/drive-t186ref-linux/lib-target
and checked two things:
cuda-9.0 is installed in usr/local/cuda-9.0/
I added the path to “libcuda.so.1” in some /etc/ld.so.conf.d/ folder’s files:
→ in “cuda-9.0.conf”
→ in “driveworks.conf”
→ in “nvidia.conf”(just to be sure, even if adding it in cuda-9.0.conf is supposed to be enough)
=========== [EDIT] ===================
I also tried the following command:
$ modprobe nvidia
$ modprobe: FATAL: Module nvidia not found in directory /lib/modules/4.13.0-36-generic
Thank you for your help.
