Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
We want to use Novatel GNSS Receiver PwrPak7D-E1 for Drive Orin Dev Kit’s GNSS, IMU sensor input.
But the DriveWorks sample application failed to connect to the Novatel device when run the command:
sudo /usr/local/driveworks/bin/sample_gps_logger --driver=gps.novatel --params=connection-type=ethernet,ip=192.168.7.7,port=2000
We configured Novatel PwrPak7D-E1 to Standalone Operation Mode, ICOM1 configuration to be static IP:192.168.7.7, Port :2000, Protocol : TCP, and enabled NEMA message GPGGA output. It is connected to the RJ45 of DriveOrin Dev Kit’s J1 MGBE-1 port. We are able to ping the PwrPak7D-E1 from DriveOrin.
From the output of sudo /usr/local/driveworks/bin/sample_sensors_info:
Sensor [19] : gps.novatel ? [connection-type={usb,ethernet},ip=X.X.X.X,port=XXXX,fifo-size=1024,timestamp-filter=true,xOffset=0.18,yOffset=0.54,zOffset=0.84][,output-timestamp={host,raw,synced,smoothed}]
Is there other params needed for “sample_gps_logger” besides “–driver=gps.novatel --params=connection-type=ethernet,ip=192.168.7.7,port=2000”. For the ethernet protocol , should orin use TCP or UDP?
Error String
[02-10-2024 20:08:54] SensorFactory::createSensor() → gps.novatel, connection-type=ethernet,ip=192.168.7.7,port=2000
[02-10-2024 20:08:54] Found driver: gps.novatel
[02-10-2024 20:08:54] Driveworks exception thrown: DW_FAILURE: EndpointNovatelEthernet: Couldn’t connect to sensor
Cannot create sensor gps.novatel with connection-type=ethernet,ip=192.168.7.7,port=2000
[02-10-2024 20:08:56] EndpointNVPPS: stopped on /dev/nvpps0
[02-10-2024 20:08:56] [02-10-2024 20:08:56] Releasing Driveworks SDK Context
Logs
wayve@mbn00004:~$ sudo /usr/local/driveworks/bin/sample_gps_logger --driver=gps.novatel --params=connection-type=ethernet,ip=192.168.7.7,port=2000
[02-10-2024 20:08:54] Platform: Detected Drive Orin P3710
[02-10-2024 20:08:54] Adding variable DW_Base:DW_Version
[02-10-2024 20:08:54] Added variable DW_Base:DW_Version
[02-10-2024 20:08:54] Platform: number of GPU devices detected 1
[02-10-2024 20:08:54] Platform: currently selected GPU device 0, Resource Data Dir: trt_08_06_10_03, Arch: ga10b
[02-10-2024 20:08:54] Platform: currently selected GPU device integrated ID 0
[02-10-2024 20:08:54] CUDLAEngine:getDLACount: CUDLA version is = 1004000
[02-10-2024 20:08:54] CUDLAEngine:getDLACount: Number of DLA devices = 2
[02-10-2024 20:08:54] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘./resources’: VirtualFileSystem: Failed to mount ‘./resources/resources.pak’
[02-10-2024 20:08:54] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/home/wayve/data’: VirtualFileSystem: Failed to mount ‘/home/wayve/data/resources.pak’
[02-10-2024 20:08:54] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-5.14/bin/…/data
[02-10-2024 20:08:54] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-5.14/bin/…/data’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-5.14/bin/…/data/resources.pak’
[02-10-2024 20:08:54] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-5.14/data
[02-10-2024 20:08:54] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-5.14/data’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-5.14/data/resources.pak’
[02-10-2024 20:08:54] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.14/bin/…/lib/libdw_base.so.5.14
[02-10-2024 20:08:54] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.14/targets/aarch64-Linux/lib/libdw_base.so.5.14
[02-10-2024 20:08:54] SDK: No resources(.pak) mounted, some modules will not function properly
[02-10-2024 20:08:54] egl::Display: found 1 EGL devices
[02-10-2024 20:08:54] egl::Display: use drm device: /dev/dri/card0
[02-10-2024 20:08:54] [02-10-2024 20:08:54] Initialize DriveWorks SDK v5.14.74
[02-10-2024 20:08:54] [02-10-2024 20:08:54] Release build with GNU 9.3.0 from buildbrain-branch-0-g30b7ba5bb0c against Drive PDK v6.0.8.0
[02-10-2024 20:08:54] SensorFactory::createSensor() → time.nvpps, nvpps-device=/dev/nvpps0
[02-10-2024 20:08:54] Found driver: time.nvpps
[02-10-2024 20:08:54] TimeSensor: failed to set NVPPS parameters. Error: Invalid argument
[02-10-2024 20:08:54] This platform does not support NVPPS GPIO mode. Fallback to timer mode
[02-10-2024 20:08:54] TimeSensor: initialized with no UTC time reference.
[02-10-2024 20:08:54] SensorFactory: Override default timeSensor with the user passed one
[02-10-2024 20:08:54] EndpointNVPPS: started on /dev/nvpps0
wayve@mbn00004:~$
