What we want to achieve is prior to sending the init-cmd, read the display IDs (0xDA 0xDB 0xDC)
To that end we are using tegra_dsi_read_data()
The display works fine in video mode after init-cmd is sent on this tx2 platform
Reading panel registers on TX2 results in FIFO being empty and a 218ms timeout with nvhost_syncpt_wait_timeout_ext()
the display responds superfast (~400ns) after IMM_BTA is given, we measured this with logical analyzer on the mipi lane. However this response ends with a timeout and empty fifo. here you can see the full 0x37 request and 0x06 read, and display answer followed by 218ms timeout in dsi.c:nvhost_syncpt_wait_timeout_ext().
zoomed in on request packets
zoomed in on display response:
We have a different platform with AM335x+toshiba mipi that reads the display fine and response can be read (so the display response is normal):
back on the TX2: added some logging to the kernel to see if we can understand what is going on.
echo "0x01 0xDA" >/sys/kernel/debug/tegra_dsi/read_panel
cat /sys/kernel/debug/tegra_dsi/read_panel
[ 2.449366] tegradc 15200000.nvdisplay: tegra_dsi_set_to_lp_mode 4
[ 2.449369] tegradc 15200000.nvdisplay: tegra_dsi_set_to_lp_mode 5
[ 2.457873] tegradc 15200000.nvdisplay: tegra_dsi_set_to_lp_mode 6
[ 2.457887] tegradc 15200000.nvdisplay: tegra_dsi_set_to_lp_mode 7
[ 2.457890] tegradc 15200000.nvdisplay: tegra_dsi_set_control_reg_lp
[ 2.457897] tegradc 15200000.nvdisplay: tegra_dsi_set_to_lp_mode 8
[ 2.457908] tegradc 15200000.nvdisplay: tegra_dsi_set_to_lp_mode 9
[ 2.473122] tegradc 15200000.nvdisplay: tegra_dc_dsi_display_detect select dsi_init_cmd
[ 2.474906] tegradc 15200000.nvdisplay: tegra_dsi_read_data_cmd pad_control_cd: 0
[ 2.474910] tegradc 15200000.nvdisplay: tegra_dsi_read_data_cmd pad_control_cd written: 30000
[ 2.474931] tegradc 15200000.nvdisplay: tegra_dsi_syncpt 7e dsi->syncpt_val+1:1 syncpt_id:b syncpt:0
[ 2.474938] tegradc 15200000.nvdisplay: tegra_dsi_read_data_cmd max_threshold 1
[ 2.474943] tegradc 15200000.nvdisplay: tegra_dsi_set_to_lp_mode 4
[ 2.474945] tegradc 15200000.nvdisplay: tegra_dsi_set_to_lp_mode 5
[ 2.483485] tegradc 15200000.nvdisplay: tegra_dsi_set_to_lp_mode 6
[ 2.483500] tegradc 15200000.nvdisplay: tegra_dsi_set_to_lp_mode 7
[ 2.483503] tegradc 15200000.nvdisplay: tegra_dsi_set_control_reg_lp
[ 2.483510] tegradc 15200000.nvdisplay: tegra_dsi_set_to_lp_mode 8
[ 2.483512] tegradc 15200000.nvdisplay: tegra_dsi_set_to_lp_mode 9
[ 2.483515] tegradc 15200000.nvdisplay: tegra_dsi_bta 1 !!!!!!
[ 2.483519] tegradc 15200000.nvdisplay: tegra_dsi_bta 2
218ms
[ 2.702022] tegradc 15200000.nvdisplay: tegra_dsi_syncpt 7e dsi->syncpt_val+1:2 syncpt_id:b syncpt:0
[ 2.702025] tegradc 15200000.nvdisplay: tegra_dsi_bta 5
[ 2.702028] tegradc 15200000.nvdisplay: tegra_dsi_bta end
[ 2.702030] tegradc 15200000.nvdisplay: tegra_dsi_read_data_cmd read_fifo
[ 2.707043] tegradc 15200000.nvdisplay: DSI RD_FIFO_CNT is zero (RD_DATA=0 dsi_status=0x400)
[ 2.707046] tegradc 15200000.nvdisplay: DSI read fifo failure
adding explicit fifo read really really looks empty
this is /sys/kernel/debug/tegra_dsi/regs after a read, but during video mode
during video mode (after all read requests
15300000: 00000000 00000000-00000000 00000000
15300010: 00000000 00000000-00000000 00000000
15300020: 0000FC00 00000000-0000DA14 00000001
15300030: 00000000 00000000-00000000 00000023
15300040: 00003032 00000018-000001E0 00000000
15300050: FFFFFFFF 00001000-0000000D 00000000 D -> experimental VID_BTA_CONTROL
15300060: 00000000 00000000-00000000 00000000
15300070: 00000000 00000000-00000000 00000000
15300080: 00000000 00000000-00000000 40000208
15300090: 00000000 40000308-00000000 40000308
153000A0: 00000000 6C8B2B08-000003F3 40000308
153000B0: 00000000 6C8B2B08-000003F3 00000000
153000C0: 00000000 00000000-00000000 00000000
153000D0: 00320000 096000DF-000001DB 0F0F0000
153000E0: 00000000 00000000-00000000 00000000
153000F0: 06070704 040A0F03-000301FF F411060E
15300100: 00000000 00000000-00000000 00000000
15300110: 20001263 F3C72000-00000000 00000000
15300120: 00000000 00000000-00000000 00000000
15300130: 00030000 00000000-00000000 00000000
15300140: 00000000 00003333-00000000 00000000
15300150: 00000000 00000000-00000000 00000000
15300160: AF363EE6 EF8DB08C-0BB576EC C1F0D0EE
15300170: BE1EE474 FB990B2E-589F450C 00000000
15300180: 002B0080 00000000-00000000 00068800
15400000: 00000000 00000000-00000000 00000000
15400010: 00000000 00000000-00000000 00000000
15400020: 0000FC00 00000000-31FDC240 00000001
15400030: 00000000 00000000-00000000 00000023
15400040: 00003032 00000018-000001E0 00000000
15400050: FFFFFFFF 00001000-0000000D 00000000
15400060: 00000000 00000000-00000000 00000000
15400070: 00000000 00000000-00000000 00000000
15400080: 00000000 00000000-00000000 40000208
15400090: 00000000 40000308-00000000 40000308
154000A0: 00000000 6C8B2B08-000003F3 40000308
154000B0: 00000000 6C8B2B08-000003F3 00000000
154000C0: 00000000 00000000-00000000 00000000
154000D0: 00320000 096000DF-000001DB 0F0F0000
154000E0: 00000000 00000000-00000000 00000000
154000F0: 06070704 040A0F03-000301FF F411060E
15400100: 00000000 00000000-00000000 00000000
15400110: 20001263 F3C72000-00000000 00000000
15400120: 00000000 00000000-00000000 00000000
15400130: 00030000 00000000-00000000 00000000
15400140: 00000000 00003333-00000000 00000000
15400150: 00000000 00000000-00000000 00000000
15400160: 5EC42D10 CFA9522E-898D71AD FE740E88
15400170: 36ACC492 E8E43801-E3E4D00C 00000000
15400180: 00100080 00000000-00000000 00068800
DSI_INCR_SYNCPT_CNTRL | 0x001 | 0x00000000 |
DSI_INCR_SYNCPT_ERROR | 0x002 | 0x00000000 |
DSI_CTXSW | 0x008 | 0x0000fc00 |
DSI_POWER_CONTROL | 0x00b | 0x00000001 |
DSI_INT_ENABLE | 0x00c | 0x00000000 |
DSI_HOST_DSI_CONTROL | 0x00f | 0x00000023 |
DSI_CONTROL | 0x010 | 0x00003032 |
DSI_SOL_DELAY | 0x011 | 0x00000018 |
DSI_MAX_THRESHOLD | 0x012 | 0x000001e0 |
DSI_TRIGGER | 0x013 | 0x00000000 |
DSI_TX_CRC | 0x014 | 0xffffffff |
DSI_STATUS | 0x015 | 0x00001000 |
DSI_INIT_SEQ_CONTROL | 0x01a | 0x00000000 |
DSI_INIT_SEQ_DATA_0 | 0x01b | 0x00000000 |
DSI_INIT_SEQ_DATA_1 | 0x01c | 0x00000000 |
DSI_INIT_SEQ_DATA_2 | 0x01d | 0x00000000 |
DSI_INIT_SEQ_DATA_3 | 0x01e | 0x00000000 |
DSI_INIT_SEQ_DATA_4 | 0x01f | 0x00000000 |
DSI_INIT_SEQ_DATA_5 | 0x020 | 0x00000000 |
DSI_INIT_SEQ_DATA_6 | 0x021 | 0x00000000 |
DSI_INIT_SEQ_DATA_7 | 0x022 | 0x00000000 |
DSI_PKT_SEQ_0_LO | 0x023 | 0x40000208 |
DSI_PKT_SEQ_0_HI | 0x024 | 0x00000000 |
DSI_PKT_SEQ_1_LO | 0x025 | 0x40000308 |
DSI_PKT_SEQ_1_HI | 0x026 | 0x00000000 |
DSI_PKT_SEQ_2_LO | 0x027 | 0x40000308 |
DSI_PKT_SEQ_2_HI | 0x028 | 0x00000000 |
DSI_PKT_SEQ_3_LO | 0x029 | 0x6c8b2b08 |
DSI_PKT_SEQ_3_HI | 0x02a | 0x000003f3 |
DSI_PKT_SEQ_4_LO | 0x02b | 0x40000308 |
DSI_PKT_SEQ_4_HI | 0x02c | 0x00000000 |
DSI_PKT_SEQ_5_LO | 0x02d | 0x6c8b2b08 |
DSI_PKT_SEQ_5_HI | 0x02e | 0x000003f3 |
DSI_DCS_CMDS | 0x033 | 0x00000000 |
DSI_PKT_LEN_0_1 | 0x034 | 0x00320000 |
DSI_PKT_LEN_2_3 | 0x035 | 0x096000df |
DSI_PKT_LEN_4_5 | 0x036 | 0x000001db |
DSI_PKT_LEN_6_7 | 0x037 | 0x0f0f0000 |
DSI_PHY_TIMING_0 | 0x03c | 0x06070704 |
DSI_PHY_TIMING_1 | 0x03d | 0x040a0f03 |
DSI_PHY_TIMING_2 | 0x03e | 0x000301ff |
DSI_BTA_TIMING | 0x03f | 0xf411060e |
DSI_TIMEOUT_0 | 0x044 | 0x20001263 |
DSI_TIMEOUT_1 | 0x045 | 0xf3c72000 |
DSI_TO_TALLY | 0x046 | 0x00000000 |
DSI_PAD_CONTROL | 0x04b | 0x00000000 |
DSI_PAD_CONTROL_CD | 0x04c | 0x00030000 |
DSI_PAD_CD_STATUS | 0x04d | 0x00000000 |
DSI_VID_MODE_CONTROL | 0x04e | 0x00000000 |
DSI_PAD_CONTROL_0_VS1 | 0x04b | 0x00000000 |
DSI_PAD_CONTROL_CD_VS1 | 0x04c | 0x00030000 |
DSI_PAD_CD_STATUS_VS1 | 0x04d | 0x00000000 |
DSI_PAD_CONTROL_1_VS1 | 0x04f | 0x00000000 |
DSI_PAD_CONTROL_2_VS1 | 0x050 | 0x00000000 |
DSI_PAD_CONTROL_3_VS1 | 0x051 | 0x00003333 |
DSI_PAD_CONTROL_4_VS1 | 0x052 | 0x00000000 |
DSI_GANGED_MODE_CONTROL | 0x053 | 0x00000000 |
DSI_GANGED_MODE_START | 0x054 | 0x00000000 |
DSI_GANGED_MODE_SIZE | 0x055 | 0x00000000 |
here is a bit of the panel dts:
26 panel_s_wuxga_8_0: panel-s-wuxga-8-0 {
27 status = "disabled";
28 compatible = "s,wuxga-8-0";
29 nvidia,dsi-instance = <DSI_INSTANCE_0>;
30 nvidia,dsi-n-data-lanes = <4>;
31 nvidia,dsi-pixel-format = <TEGRA_DSI_PIXEL_FORMAT_24BIT_P>;
32 nvidia,dsi-refresh-rate = <60>;
33 nvidia,dsi-video-data-type = <TEGRA_DSI_VIDEO_TYPE_VIDEO_MODE>;
34 nvidia,dsi-video-clock-mode = <TEGRA_DSI_VIDEO_CLOCK_CONTINUOUS>; //TEGRA_DSI_VIDEO_CLOCK_TX_ONLY
35 nvidia,dsi-lp00-pre-panel-wakeup = <TEGRA_DSI_DISABLE>;
36 /*nvidia,enable-hs-clk-in-lp-mode;*/
37 nvidia,dsi-video-burst-mode = <TEGRA_DSI_VIDEO_NONE_BURST_MODE>;
38 /*
39 nvidia,dsi-ganged-type = <TEGRA_DSI_GANGED_SYMMETRIC_LEFT_RIGHT>;
40 nvidia,dsi-ganged-swap-links = <1>;
41 nvidia,dsi-ganged-write-to-all-links = <1>;
42 */
43
44 /*nvidia,dsi-phy-hsdexit = <123>; /* dsi phy timing, t_hsdexit_ns.*/
45 /*nvidia,dsi-phy-hstrail = <85>; /* dsi phy timing, t_hstrail_ns.*/
46 /*nvidia,dsi-phy-datzero = <170>; /* dsi phy timing, t_datzero_ns.*/
47 /*nvidia,dsi-phy-hsprepare = <57>; /* dsi phy timing, t_hsprepare_ns.*/
48
49 /*nvidia,dsi-phy-clktrail = <1>; /* dsi phy timing, t_clktrail_ns.*/
50 /*nvidia,dsi-phy-clkpost = <1>; /* dsi phy timing, t_clkpost_ns.*/
51 /*nvidia,dsi-phy-clkzero = <1>; /* dsi phy timing, t_clkzero_ns.*/
52 /*nvidia,dsi-phy-tlpx = <1>; /* dsi phy timing, t_tlpx_ns.*/
53 /*nvidia,dsi-phy-clkprepare = <1>; /* dsi phy timing, t_clkprepare_ns.*/
54 /*nvidia,dsi-phy-clkpre = <1>; /* dsi phy timing, t_clkpre_ns.*/
55 /*nvidia,dsi-phy-wakeup = <1>; /* dsi phy timing, t_wakeup_ns.*/
56
57 nvidia,dsi-phy-tpktbta = <4000>; /* dsi phy timing, t_taget_ns.*/
58 /* nvidia,dsi-phy-taget = <200>; /* dsi phy timing, t_taget_ns.*/
59 /* nvidia,dsi-phy-tasure = <400>; /* dsi phy timing, t_tasure_ns.*/
60 /* nvidia,dsi-phy-tago = <600>; /* dsi phy timing, t_tago_ns. */
61
62 nvidia,dsi-controller-vs = <DSI_VS_1>;
63 nvidia,dsi-virtual-channel = <TEGRA_DSI_VIRTUAL_CHANNEL_0>;
64 nvidia,dsi-panel-reset = <TEGRA_DSI_ENABLE>;
65 nvidia,dsi-ulpm-not-support = <TEGRA_DSI_DISABLE>;
66 nvidia,dsi-suspend-stop-stream-late = <TEGRA_DSI_ENABLE>;
67 nvidia,dsi-power-saving-suspend = <TEGRA_DSI_DISABLE>;
68 nvidia,default_color_space = <1>; /*default color profile:adobeRGB*/
69 nvidia,dsi-init-cmd =
329 nvidia,dsi-pkt-seq =
330 <CMD_VS LEN_SHORT PKT_LP LINE_STOP>,
331 <CMD_HS LEN_SHORT PKT_LP LINE_STOP>,
332 <CMD_HS LEN_SHORT PKT_LP LINE_STOP>,
333 <CMD_HS LEN_SHORT CMD_BLNK LEN_HBP CMD_BLNK LEN_SHORT CMD_RGB_24BPP LEN_HACTIVE3 PKT_LP LINE_STOP>,
334 <CMD_HS LEN_SHORT PKT_LP LINE_STOP>,
335 <CMD_HS LEN_SHORT CMD_BLNK LEN_HBP CMD_BLNK LEN_SHORT CMD_RGB_24BPP LEN_HACTIVE3 PKT_LP LINE_STOP>;
336
we have tried a lot of different things:
-trying to control the BTA through PKT_BTA instead of IMM_BTA, to delay the display response to generate time for jetson to read response by 4us ( nvidia,dsi-phy-tpktbta = <4000>;)
-tried VID_BTA_CONTROL to continuously set and/or change the BTA line (in command mode this will do nothing we think).
-tried all sorts of nvidia,dsi-pkt-seq
-tried TearingEffect 0x35
-tried changing the read function to change max_threshold and trigger on fifo_level
-tried to change dsi-ulpm-not-support
-tried dsi-video-clock-mode continuous and tx_only
-tried syncpt OP_MODE | RD_MODE , but then the kernel deadlocks) (we do not know how syncpts work)
-measured the voltages for logical 0, and logical 1 are OK
so the BTA handover to display seems to work,
response from display is OK,
last part of of display response seems to be a BTA,
but after that bus handover to jetson it seems to timeout 218ms as if
-jetson has not seen the response, causing syncpt timeeout
-or jetson waits for a different syncpt causing syncpt timeout
so my simplest questions would be:
does the function dsi.c:tegra_dsi_read_data() work?
and what variables should we look at that could cause fifo to remain empty and syncpt to timeout?
