Hello
Let’s start with the fact that I have a laptop with an RTX 3050. I ran into the problem that I have no DSR settings in the NVIDIA Control Panel. Is there a way to enable it, or laptop GPU’s just don’t support DSR?
p.s. Sorry if my English is not very good
Hi there @justfeeliteffect and welcome to the NVIDIA developer forums!
Usually regarding GeForce questions you are better served on the dedicated GeForce Forums, you can also find threads on the topic of DSR on Laptops over there.
As summary: For DSR to be available the GPU needs to be directly connected to the Display device. On most modern Laptops this is not the case since they work in a Hybrid way where the integrated Graphics Unit of the CPU will do most rendering, while the GPU only kicks in on-demand and then gets its output routed through to the integrated Display.
If you have the option to connect external panels through HDMI, DP or USB-C, then the DSR option should appear in the Control Panel settings, depending on the Hardware setup of your specific laptop.
I hope that helps!
