Enable CAD Converter extension
I found this link about a CAD converter extension: CAD Converter — extensions latest documentation
I want to use that extension because I want to import a NX - Unigraphics Files (*.prt) file. It says in the link that you just need to activate it. But the problem is I can’t find it anywhere. Does it still exist and if it does how do I enable it?
Thanks in advance.
p.s. I need to do this because I can’t import step 214 and 242, isaac sim crashes if I do that.
I found out that it is available on Windows but not on Linux. Is it possible to do it also on Linux?
Hi @nickbakker40 - You are right. CAD Converter extension is currently supported only on Windows.
