Problem adding cad importer
Hi, i am opening the create extensions , but can’t find cad importer
Could you describe the steps you are taking to search for the extension?
There are two extensions for importing cad documents: Cad importer (formerly called step importer) and Onshape Importer. Which one are you trying to use?
i open the create app, when we open window-> extentions, i don’t see there Cad importer or Onshape Importer, the only importer i have is Asset importer
asset
Hi @gaby1
It looks like the CAD (Step) Importer and the Onshape Importer may not publicly available extensions for Create.
I am working on getting more information about this.
I am also interested in looking in to the cad importer. ¨
In the release notes for Create 2022.1.0 under Extension Changes, it says “removed extension omni.kit.importer.cad”.
Check this out. it works now, Jack!
Nice, it works!
I get this error message when I try to apply a material.
I also get a lot of subsets which are difficult to work with. Is there something during the import that I can change that will effect that?
the main USD it creates ( in the end of my video you se that scene ok in the background, it ends before I give name and destination for it but it just saves all there ) is called “_270a0004_roskiskokoonpano.usd” in my video above.
Now If I open that scene, I can assign new materials:
I just dragged the “steel blued” metal material on that mesh and tweaked a green tint on it.
