In our custom board we are using Jetson Nano SOM and we want to interface LVDS display into DSI interface using DSI to LVDS bridge converter SN65DSI83.
I have referred to the following forum post and made changes to my kernel & dts and now sn65dsi83 bridge driver seems to be loaded successfully and no errors in its interrupt status regs (0xE5) but still I can’t see anything on the display, just white screen. what am missing here ?
DTSI
host1x {
/* DSI mapped to tegradc.1 */
dc@54240000 {
status = "okay";
nvidia,dc-or-node = "/host1x/dsi";
nvidia,dc-connector = <&dsi>;
/* DSI supplies */
avdd_dsi_csi-supply = <&max77620_sd3>;
avdd_lcd-supply = <&battery_reg>;
dvdd_lcd-supply = <&battery_reg>;
vdd_lcd_bl_en-supply = <&battery_reg>;
vdd_lcd_bl-supply = <&battery_reg>;
dsi {
nvidia,dsi-controller-vs = <DSI_VS_1>;
status = "okay";
nvidia,active-panel = <&panel_dsi2lvds>;
panel_dsi2lvds: panel_dsi2lvds {
status = "okay";
compatible = "c,wxga-14-0";
nvidia,dsi-instance = <0>;
nvidia,dsi-n-data-lanes = <2>;
nvidia,dsi-pixel-format = <3>; /* 24 bit planar*/
nvidia,dsi-refresh-rate = <60>;
nvidia,dsi-video-data-type = <0>; //TEGRA_DSI_VIDEO_TYPE_VIDEO_MODE
nvidia,dsi-video-clock-mode = <0>; //Continuous clock (1-tx)
nvidia,dsi-video-burst-mode = <1>;
nvidia,dsi-ganged-type = <0>; /* 0= not used, 1=left/right, 2=odd/even 3=overlapped ?*/
nvidia,dsi-split-link-type= <0>; /* split link, 1=A/B) */
nvidia,dsi-ganged-swap-links = <0>;
nvidia,dsi-ganged-write-to-all-links = <0>;
nvidia,dsi-controller-vs = <1>;
nvidia,dsi-virtual-channel = <0>;
nvidia,dsi-panel-reset = <1>;
//nvidia,panel-bl-pwm-gpio = <&tegra_aon_gpio TEGRA_AON_GPIO(V, 0) 1>; /* PV0 */
nvidia,dsi-ulpm-not-support = <1>;
nvidia,dsi-suspend-stop-stream-late = <1>;
nvidia,dsi-power-saving-suspend = <1>;
nvidia,default_color_space = <1>;
pwms = <&tegra_pwm 0 40161>;
disp-default-out {
nvidia,out-type = <2>;
nvidia,out-width = <216>;
nvidia,out-height = <135>;
nvidia,out-flags = <(0 << 3)>;
nvidia,out-xres = <1280>;
nvidia,out-yres = <800>;
display-timings {
/delete-node/ 1200x1920-32-60Hz; /* remove existing resolution */
1280x800-32-60Hz {
clock-frequency = <72000000>;
hactive = <1280>;
vactive = <800>;
hfront-porch = <72>;
hback-porch = <88>;
vfront-porch = <15>;
vback-porch = <23>;
hsync-len = <13>;
vsync-len = <2>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <1>;
nvidia,h-ref-to-sync = <1>;
nvidia,v-ref-to-sync = <11>;
DTS:
i2c@7000c000 {
status = "okay";
sn65dsi84_1: sn65dsi84@2c {
status = "okay";
compatible = "ti,sn65dsi83";
reg = <0x2c>;
ti,dsi-lanes = <2>;
ti,lvds-format = <0>;
ti,lvds-bpp = <24>;
ti,width-mm = <216>;
ti,height-mm = <135>;
ti,lvds-channels = <1>;
ti,always-on=<1>;
ti,no-drm-connect=<1>;
ti,reverse-lvds=<0>;
dsi-lanes = <2>;
panel-width-mm = <216>;
panel-height-mm = <135>;
display-timings {
timing {
hactive = <1280>;
vactive = <800>;
hback-porch = <88>;
vback-porch = <23>;
hsync-len = <13>;
vsync-len = <2>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <1>;
port {
panel1_in: endpoint {
remote-endpoint = <&mipi_dsi_bridge_out>;
mipi_dsi_bridge {
status = "okay";
clock-drop-level = <1>;
port@1 {
mipi_dsi_bridge_out: endpoint {
remote-endpoint = <&panel_dsi2lvds>;
Log:
dmesg_log.txt (10.3 KB)
After 5mins, I see ‘powerdown’ and also I see SN65DSI83’s 0xE5 register set from 0x0 to 0x1 (i.e PLL LOCK to UNLOCK) and I did ‘echo 0 > /sys/class/graphics/fb1/blank’, then again it got back to 0.(PLL LOCK)
Stil nothing seen in display.
Log:
[ 309.619723] sn65dsi83 0-002c: sn65dsi83_read: read reg 0xe5 data 0x00
[ 309.627644] sn65dsi83 0-002c: sn65dsi83_write: write reg 0xe5 data 0xff
[ 326.186726] tegradc tegradc.1: blank - powerdown
[ 331.122702] sn65dsi83 0-002c: sn65dsi83_read: read reg 0xe5 data 0x01
[ 331.130431] sn65dsi83 0-002c: sn65dsi83_write: write reg 0xe5 data 0xff
[ 352.626328] sn65dsi83 0-002c: sn65dsi83_read: read reg 0xe5 data 0x01
[ 352.633878] sn65dsi83 0-002c: sn65dsi83_write: write reg 0xe5 data 0xff
[ 374.129588] sn65dsi83 0-002c: sn65dsi83_read: read reg 0xe5 data 0x01
[ 374.136800] sn65dsi83 0-002c: sn65dsi83_write: write reg 0xe5 data 0xff
[ 391.645032] tegradc tegradc.1: unblank
[ 391.645383] vdd_ds_1v8 regulator get failed
[ 391.645399] lvds regulator get failed
[ 391.677395] tegradc tegradc.1: nominal-pclk:1666000 parent:9995947 div:6.0 pclk:1665991 1649340~1815940
[ 391.677986] tegradc tegradc.1: DSI: HS clock rate is 440000
[ 395.633070] sn65dsi83 0-002c: sn65dsi83_read: read reg 0xe5 data 0x01
[ 395.641061] sn65dsi83 0-002c: sn65dsi83_write: write reg 0xe5 data 0xff
[ 417.137099] sn65dsi83 0-002c: sn65dsi83_read: read reg 0xe5 data 0x00
[ 417.144639] sn65dsi83 0-002c: sn65dsi83_write: write reg 0xe5 data 0xff
[ 438.640384] sn65dsi83 0-002c: sn65dsi83_read: read reg 0xe5 data 0x00
[ 438.648466] sn65dsi83 0-002c: sn65dsi83_write: write reg 0xe5 data 0xff
[ 460.145919] sn65dsi83 0-002c: sn65dsi83_read: read reg 0xe5 data 0x00
[ 460.153251] sn65dsi83 0-002c: sn65dsi83_write: write reg 0xe5 data 0xff
[ 481.648832] sn65dsi83 0-002c: sn65dsi83_read: read reg 0xe5 data 0x00
root@jetson-03:~#
root@jetson-03:~# cat /dev/urandom > /dev/fb1
cat: write error: No such device
root@jetson-03:~#
root@jetson-03:~#
Kindly let me know if need more details. Thanks.
any insights would be helpful.
