DRIVE OS Version: 6.0.10
Issue Description: Cannot find how to create encrypted root filesystem on DriveOS 6.0.10 but I could find it in older archived document.
I would like to ensure root filesystem content is safe at-rest. For that I wanted to use LUKS(cryptsetup) auto-decrypted by Trusted Platform Module 2.0 hardware like I use it with my ubuntu.
I’ve read the following documentation but it only suppors secure boot and encrypted /home filesystem:
Before reading the latest, I was browsing the older one, which is describing how to flash the root filesystem in encrypted way.
The questions are:
- Can I have the root filesystem encrypted on driveos 6.0.10 on Hardware Drive AGX Orin?
- Can I use TPM2.0 to specify the password automatically on boot like I use it on my ubuntu 2024?
Dear SivaRamaKrishnaNV
Thank you very much for the quick response.
It clarifies a bit.
Without root filesystem encryption and automatic decryption how do you suggest to protect Intellectual Properties of both NVIDIA and aiMotive from being reverse engineered by customers?
Otto
And what about Trusted Platform Module 2.0?
The Cortex A78A supports FT-A by firmware/hardware that can enable TPM2.0 device in linux.
Default kernel does not support TPM (dmesg | grep -i tpm has no output) but can it be enabled in our build?
Otto
Can you help us modifying the flash.py script to implement root filesystem encryption if we decide to do so?
Otto
Encrypting entire RFS is not part of POR. It is not supported.
Note that Jetson is different from DRIVE.
Jetson (L4T) support fTPM Firmware TPM — NVIDIA Jetson Linux Developer Guide 1 documentation but not DRIVE OS (it’s not auto POR).
