Error: command error code: 67
I am doing it. Install Jetpack through SDK Manager
However, after flashing Jetson Linux, the next step is not possible. error: command error code: 67
info: Event: - error code is: 1067
due to
Could you please confirm the log attached?
BR
SDKM_logs_2025-02-26_09-59-18.zip (404.7 KB)
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
Since you flash your Linux Image successfully, could you access the system through ssh, minicom or monitor?
