Error: Could not detect correct NVIDIA Jetson device connected to USB port
I want to flash my old xavier nx devkit (sd version with original board) with nvme boot.
with sdkmanager_2.2.0-12021_amd64 on Ubuntu 20.04 LTS
but it failed to detect the usb connection.
the lsusb can see the device.
root@unb:/home/guru/.nvsdkm# lsusb
Bus 002 Device 005: ID 2717:5013 Xiaomi Inc.
Bus 002 Device 004: ID 320f:5088
Bus 002 Device 003: ID 0ac8:301b Z-Star Microelectronics Corp. ZC0301 Webcam
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0b05:17b5 ASUSTek Computer, Inc.
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 0955:7e19 NVIDIA Corp. APX
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
here’s the log.
sdkm-2024-11-03-14-55-29.log (978.8 KB)
any suggestions?
thanks.
Are you using a VM? If so, then this would tend to cause failure. Also, what was your flash command? You do need the initrd script to flash to an NVMe.
