Error Jetson OKDO C100
Hi, I don’t know if I am posting in the correct part of the forum.
I just bought a Jetson OKDO C100, which is a version of the Jetson Nano Developer Kit with 4GB. I downloaded the C100 OS version from GitHub - LetsOKdo/c100-bootupd: Custom bootloader for OKdo Nano C100 to enable microSD boot and the 4.6.5 version from the official NVIDIA website, but both produce different errors.
The C100 image produces the following error:
[ 1.177435] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.385966] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.386098] imx219 7-0010: board setup failed
[ 1.410380] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.410457] imx219 8-0010: board setup failed
mount: /mnt: wrong fs type, bad option, bad superblock on /dev/mcblk1p1, missing codepage or helper program, or other error.
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-4.4#
And the OS from NVIDIA produces the following error (see image):
This is the NVIDIA download page: JetPack SDK 4.6.5 | NVIDIA Developer. I downloaded it from the Jetson Nano Developer Kits section.
Just to clarify. That thing you are using and talking about is not a NV devkit.
This means we don’t guarantee NV default software would work on it.
It seems this vendor provide you some software method to enable the interfaces on the board. Are you sure you apply it correctly?
You can try to boot from eMMC first instead of sdcard.
