Error when try to run source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt on redhat linux
Hello All
i am trying to setup a deepstream docker enviornment on redhat linux 7 and when i try to run a sample model i get the following error
** ERROR: <parse_config_file:532>: parse_config_file failed
** ERROR: main:627: Failed to parse config file ‘sourc’
My hardware platform is gpu
VGA compatible controller: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Dell Device 3600
Flags: bus master, fast devsel, latency 0, IRQ 152
Memory at de000000 (32-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
[virtual] Expansion ROM at df000000 [disabled] [size=512K]
Capabilities:
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
Deep Stream version
docker.io/nvidia/cuda 10.0-base b1a3d27ab8dc 4 weeks ago 109 MB
docker.io/hello-world latest d1165f221234 6 weeks ago 13.3 kB
deepstream 5.1-21.02-triton f7b156254552 8 weeks ago 13.4 GB
deepstream 5.1-21.02-base 1df50dfdce65 8 weeks ago 6.38 GB
cuda 11.0-base 2ec708416bb8 8 months ago 122 MB
docker version
Client:
Version: 1.13.1
API version: 1.26
Package version: docker-1.13.1-204.git0be3e21.el7_9.x86_64
Go version: go1.10.3
Git commit: 0be3e21/1.13.1
Built: Fri Feb 12 08:57:04 2021
OS/Arch: linux/amd64
Server:
Version: 1.13.1
API version: 1.26 (minimum version 1.12)
Experimental: false
any help will be gladly be apricated
Please check your configuration, should be group source not group sourc.
Hello Amycao
please can you guide which file do i make that change as i pretty new to this
sudi
Can you upload the configuration file you used?
some info about this,
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_sample_configs_streams.html
Hello Amycao
is there a instruction or guide i can follow on how to copy these configs files as i tried it a lot
but am not able to find any guide on how to copy them from the docker container
thanks
sudi
docker cp CONTAINER ID:/file path in docker you want to copy/ /local path/
you can get CONTAINER ID from docker ps
Hello amycao
please find the attached files as requested
sudi Configs_Files .zip (91.8 KB)
I mean the configuration you used when run the app, not the whole config package.
Hello Amycao
Please find the attached file as requested the
source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt (5.7 KB)
Hello amycao
i have not heard any back from you is there a possibility for me to have a meeting with you through zoom or any mode of communication for the help
sudi
Hello Amycao,
am following up with the following issue any help would be appreciated
sudi
Sorry for the long delay.
from the config file, seems right.
the error come from deepstream_app_main.c:
if (!parse_config_file (&appCtx[i]->config, cfg_files[i])) {
NVGSTDS_ERR_MSG_V (“Failed to parse config file ‘%s’”, cfg_files[i]);
appCtx[i]->return_value = -1;
goto done;
Can you try with another configuration not modified and see what going on?
Am getting the same error message have tried all the config files please advice what else can i try
Note:is there a possibility to schedule a support meeting for you to just have a look if i am not missing anything
sudi
Can you paste the command you used and the whole log? besides, in docker, which os and version you used?
Machine os and version
computer-server
Chassis: server
Machine ID: 9d4c73dd9c9b4ceebeb1e17787fd2c40
Boot ID: 5bc935d8d0f84a9cb6824efe500a2657
Operating System: Red Hat Enterprise Linux
CPE OS Name: cpe:/o:redhat:enterprise_linux:7.9:GA:server
Kernel: Linux 3.10.0-1160.24.1.el7.x86_64
Architecture: x86-64
Command use
sudo docker run -it --rm -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-5.1 nvcr.io/nvidia/deepstream:5.1-21.02-triton
To run the sample
deepstream-app -c source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
Log
Please can you tell me what log are you looking for
the output when you run the sample from the terminal.
Output
  • ERROR: <parse_config_file:532>: parse_config_file failed
    ** ERROR: main:627: Failed to parse config file ‘source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt’
    Quitting
    App run failed
I just use your attached source4*** configuration to run, with success. and i also tried triton docker nvcr.io/nvidia/deepstream:5.1-21.02-triton, also success.
can you remove the cache, rm ~/.cache/gstreamer-1.0/ -rf and try again. if still fail, please pull one clean docker and try again.
Hello Amycao,
i tried with the clean docker and the following problem is popping up
root@78faef9ce65f:/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app# deepstream-test5-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt
** ERROR: main:1451: Failed to set pipeline to PAUSED
Quitting
App run failed
sudi
Please do below before run docker
export DISPLAY=:0 or 1 //xrandr to check if display exported or not
xhost +
another option is you can use sink type 1 Fakesink or 3 File in configuration.
