I am trying to install Jetpack 4.5.1 using SDK manager method, but I am getting many errors(Not even a single thing was installed) while downloading and installing on target machine.
What should be the follow up?
Share the error log.
~/.nvsdkm/logs/ shall record them.
Here is the log file.
JetsonAGX_log (4.7 KB)
Can you share the information of your host?
That issue is resolved, I am facing a new issue now.
I am getting an error while installing SDK components on my Jetson AGX Xavier
What might be the reason?
Again, share the log… it is impossible to know what happens with just a “I am getting error” comment.
Also, please directly copy the whole directory as the tarball and attach it here. Not just a log file.
There isn’t any option to download log, since there is a pop-up to install SDK components onto the Jetson Xavier. If there is a method to get log please tell.
Could not connect to the target device. Verify that:
~/.nvsdkm/logs/ is the place for the log…
If this is just you cannot get usb device mode get connected, then maybe you can use ethernet IP to send file.
USB device mode also requires your host to support. Unfortunately that some users’ host seems not able to have that interface. I will suggest directly use ethernet to do the work to save your time.
SDKM_logs_JetPack_4.5.1_Linux_for_Jetson_AGX_Xavier_2021-07-09_10-43-01.zip (389.3 KB)
SDKM_logs_2021-07-09_13-45-54.zip (986.3 KB)
Just want to check. Can you share both of your ifconfig result on host and xavier?
Looks like the usb virtual eth interface does not work on your host.
Is your flash cable still connected on your host?
Can you hotplug that cable and share what is printed in your host dmesg?
which specific part of dmesg is required?
Just share what is new after you hotplug the usb cable.
[161675.726667] sd 3:0:0:0: Power-on or device reset occurred
[161675.727379] sd 3:0:0:0: [sdb] 32768 512-byte logical blocks: (16.8 MB/16.0 MiB)
[161675.727543] sd 3:0:0:0: [sdb] Write Protect is on
[161675.727550] sd 3:0:0:0: [sdb] Mode Sense: 0f 00 80 00
[161675.727709] sd 3:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[161675.730466] sdb:
[161675.732052] sd 3:0:0:0: [sdb] Attached SCSI removable disk
Are you missing this log or this kind of log really does not appear?
[3037081.533072] usb 2-1.7: new high-speed USB device number 7 using ehci-pci
[3037081.642967] usb 2-1.7: New USB device found, idVendor=0955, idProduct=7020
[3037081.642971] usb 2-1.7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[3037081.642972] usb 2-1.7: Product: Linux for Tegra
[3037081.642974] usb 2-1.7: Manufacturer: NVIDIA
[3037081.642976] usb 2-1.7: SerialNumber: 1413320000115
And is your host machine has cdc_ncm and cdc acm driver installed? These driver should come out and setup the interface for you.
[161592.824637] sd 3:0:0:0: Power-on or device reset occurred
[161592.824893] sd 3:0:0:0: [sdb] 32768 512-byte logical blocks: (16.8 MB/16.0 MiB)
[161592.825044] sd 3:0:0:0: [sdb] Write Protect is on
[161592.825049] sd 3:0:0:0: [sdb] Mode Sense: 0f 00 80 00
[161592.825194] sd 3:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[161592.827989] sdb:
[161592.829647] sd 3:0:0:0: [sdb] Attached SCSI removable disk
[161658.854760] usb 2-3: USB disconnect, device number 15
[161658.854850] rndis_host 2-3:1.0 enp0s20f0u3: unregister ‘rndis_host’ usb-0000:00:14.0-3, RNDIS device
[161658.936301] cdc_ncm 2-3:1.5 enp0s20f0u3i5: unregister ‘cdc_ncm’ usb-0000:00:14.0-3, CDC NCM
[161674.657889] usb 2-3: new SuperSpeed Gen 1 USB device number 16 using xhci_hcd
[161674.679527] usb 2-3: New USB device found, idVendor=0955, idProduct=7020, bcdDevice= 0.02
[161674.679532] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[161674.679535] usb 2-3: Product: Linux for Tegra
[161674.679538] usb 2-3: Manufacturer: NVIDIA
[161674.679540] usb 2-3: SerialNumber: 1421220031377
[161674.687652] rndis_host 2-3:1.0 usb0: register ‘rndis_host’ at usb-0000:00:14.0-3, RNDIS device, 66:e1:4a:ac:8c:d4
[161674.689536] cdc_acm 2-3:1.2: ttyACM0: USB ACM device
[161674.692013] usb-storage 2-3:1.4: USB Mass Storage device detected
[161674.695596] scsi host3: usb-storage 2-3:1.4
[161674.719156] cdc_ncm 2-3:1.5: MAC-Address: 86:15:0f:4a:40:12
[161674.720064] cdc_ncm 2-3:1.5 usb1: register ‘cdc_ncm’ at usb-0000:00:14.0-3, CDC NCM, 86:15:0f:4a:40:12
[161674.818228] rndis_host 2-3:1.0 enp0s20f0u3: renamed from usb0
[161674.857311] cdc_ncm 2-3:1.5 enp0s20f0u3i5: renamed from usb1
[161675.722827] scsi 3:0:0:0: Direct-Access Linux File-Stor Gadget 0409 PQ: 0 ANSI: 2
[161675.723486] sd 3:0:0:0: Attached scsi generic sg1 type 0
And, previously same host was used to flash, but while re-flashing I am getting this issue
Are you sure the dmesg you just shared is the full log?
I see the interface comes out as enp0s20f0u3i5 and enp0s20f0u3 but it seems they are not getting enabled.
For example, this is from my host when usb cable is connected.
037081.761906] cdc_ncm 2-1.7:1.5 enp0s29u1u7i5: renamed from usb0
[3037081.784884] usb-storage 2-1.7:1.4: USB Mass Storage device detected
[3037081.785070] scsi host6: usb-storage 2-1.7:1.4
[3037081.785141] usbcore: registered new interface driver usb-storage
[3037081.796856] IPv6: ADDRCONF(NETDEV_UP): enp0s29u1u7i5: link is not ready
[3037081.796969] IPv6: ADDRCONF(NETDEV_UP): enp0s29u1u7i5: link is not ready
[3037081.801706] usbcore: registered new interface driver uas
[3037081.856256] cdc_ncm 2-1.7:1.5 enp0s29u1u7i5: 425 mbit/s downlink 425 mbit/s uplink
[3037081.888272] cdc_ncm 2-1.7:1.5 enp0s29u1u7i5: 425 mbit/s downlink 425 mbit/s uplink
[3037081.920299] IPv6: ADDRCONF(NETDEV_CHANGE): enp0s29u1u7i5: link becomes ready
