I ues gdm as default dm. The error logs show as belowed:
grep systemd1 /var/log/syslog
Mar 28 01:54:10 eis200r dbus-daemon[558]: [system] Successfully activated service 'org.freedesktop.systemd1'
Mar 28 01:54:15 eis200r /usr/lib/gdm3/gdm-x-session[1581]: dbus-daemon[1581]: [session uid=124 pid=1581] Activating service name='org.freedesktop.systemd1' requested by ':1.3' (uid=124 pid=1582 comm="/usr/libexec/gnome-session-binary --systemd --auto" label="kernel")
Mar 28 01:54:15 eis200r /usr/lib/gdm3/gdm-x-session[1581]: dbus-daemon[1581]: [session uid=124 pid=1581] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Mar 28 01:54:15 eis200r /usr/lib/gdm3/gdm-x-session[1581]: dbus-daemon[1581]: [session uid=124 pid=1581] Activating service name='org.freedesktop.systemd1' requested by ':1.4' (uid=124 pid=1582 comm="/usr/libexec/gnome-session-binary --systemd --auto" label="kernel")
Mar 28 01:54:15 eis200r gnome-session[1582]: gnome-session-binary[1582]: WARNING: Falling back to non-systemd startup procedure due to error: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
Mar 28 01:54:15 eis200r gnome-session-binary[1582]: WARNING: Falling back to non-systemd startup procedure due to error: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
Mar 28 01:54:17 eis200r dbus-daemon[1768]: [session uid=0 pid=1766] Activating service name='org.freedesktop.systemd1' requested by ':1.5' (uid=0 pid=1814 comm="dbus-update-activation-environment --systemd SSH_A" label="kernel")
Mar 28 01:54:17 eis200r dbus-daemon[1768]: [session uid=0 pid=1766] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Mar 28 01:54:18 eis200r /usr/lib/gdm3/gdm-x-session[1581]: dbus-daemon[1581]: [session uid=124 pid=1581] Activating service name='org.freedesktop.systemd1' requested by ':1.10' (uid=124 pid=1821 comm="/usr/libexec/gsd-sharing " label="kernel")
Mar 28 01:54:18 eis200r /usr/lib/gdm3/gdm-x-session[1581]: dbus-daemon[1581]: [session uid=124 pid=1581] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Mar 28 01:54:18 eis200r gsd-sharing[1821]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
Mar 28 01:54:18 eis200r gsd-sharing[1821]: message repeated 3 times: [ Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1]
These error logs don’t exist on devkit. I tested on custom carrier.
These logs appear when the default user is common user.
When I set root as default user, these logs disappear. But they appear again when I start vnc service, which shows like this:
These logs are harmless to the display function. I want to know the reason and whether this phenomenon appears on custom carrier or not.
Thank you all.
Hi, DaneLLL,
My default name is orin, please help to check whether there is a problem with my environment.
$ groups orin
orin : wheel adm sudo audio video render gdm weston-launch
$ getent group gdm
gdm:x:130:orin
$ grep gdm /etc/passwd
gdm:x:124:130:Gnome Display Manager:/var/lib/gdm3:/bin/false
Here is startup logs related to this topic:
Mar 28 01:54:10 eis200r dbus-daemon[596]: [system] Successfully activated service 'org.freedesktop.systemd1'
Mar 28 01:54:15 eis200r /usr/lib/gdm3/gdm-x-session[1527]: dbus-daemon[1527]: [session uid=124 pid=1527] Activating service name='org.freedesktop.systemd1' requested by ':1.3' (uid=124 pid=1528 comm="/usr/libexec/gnome-session-binary --systemd --auto" label="kernel")
Mar 28 01:54:15 eis200r /usr/lib/gdm3/gdm-x-session[1527]: dbus-daemon[1527]: [session uid=124 pid=1527] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Mar 28 01:54:15 eis200r /usr/lib/gdm3/gdm-x-session[1527]: dbus-daemon[1527]: [session uid=124 pid=1527] Activating service name='org.freedesktop.systemd1' requested by ':1.4' (uid=124 pid=1528 comm="/usr/libexec/gnome-session-binary --systemd --auto" label="kernel")
Mar 28 01:54:15 eis200r gnome-session[1528]: gnome-session-binary[1528]: WARNING: Falling back to non-systemd startup procedure due to error: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
Mar 28 01:54:15 eis200r gnome-session-binary[1528]: WARNING: Falling back to non-systemd startup procedure due to error: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
Mar 28 01:54:18 eis200r /usr/lib/gdm3/gdm-x-session[1527]: dbus-daemon[1527]: [session uid=124 pid=1527] Activating service name='org.freedesktop.systemd1' requested by ':1.13' (uid=124 pid=1649 comm="/usr/libexec/gsd-sharing " label="kernel")
Mar 28 01:54:18 eis200r /usr/lib/gdm3/gdm-x-session[1527]: dbus-daemon[1527]: [session uid=124 pid=1527] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Mar 28 01:54:18 eis200r gsd-sharing[1649]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
Mar 28 01:54:18 eis200r gsd-sharing[1649]: message repeated 3 times: [ Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1]
I use HDMI interface and have no other operations about gdm.
