Errors were encountered while processing: /var/cache/apt/archives/nvidia-l4t-core_35.3.1-20230319081403_arm64.deb
Hi, I’m one of the reviewers of the Jetson Orin Nano Developer Kit.
It’s pretty good. The performance is amazing.
I’ve met a problem below and cannot apt install anything now. Do you have some advice to resolve it?
sudo apt upgrade
[sudo] password for youtalk:
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
 nvidia-l4t-jetsonpower-gui-tools : Depends: nvidia-l4t-core (= 35.3.1-20230319081403) but 35.3.0-20230221103601 is installed
 nvidia-l4t-nvfancontrol : Depends: nvidia-l4t-core (= 35.3.1-20230319081403) but 35.3.0-20230221103601 is installed
 nvidia-l4t-nvpmodel : Depends: nvidia-l4t-core (= 35.3.1-20230319081403) but 35.3.0-20230221103601 is installed
 nvidia-l4t-nvpmodel-gui-tools : Depends: nvidia-l4t-core (= 35.3.1-20230319081403) but 35.3.0-20230221103601 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I’ve tried to run sudo apt --fix-broken install but it didn’t work.
sudo apt --fix-broken install nvidia-l4t-core
The following packages were automatically installed and are no longer required:
  apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin dctrl-tools dpkg-repack gir1.2-goa-1.0 gir1.2-timezonemap-1.0 gir1.2-xkl-1.0
  grub-common libdebian-installer4 libfwupdplugin1 libtimezonemap-data libtimezonemap1 libxmlb1 os-prober python3-icu python3-pam rdate tasksel
  tasksel-data
Use 'sudo apt autoremove' to remove them.
The following packages will be upgraded:
  nvidia-l4t-core
1 upgraded, 0 newly installed, 0 to remove and 66 not upgraded.
26 not fully installed or removed.
Need to get 6,164 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 https://repo.download.nvidia.com/jetson/t234 r35.3/main arm64 nvidia-l4t-core arm64 35.3.1-20230319081403 [6,164 kB]
Fetched 6,164 kB in 1s (8,209 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
(Reading database ... 155378 files and directories currently installed.)
Preparing to unpack .../nvidia-l4t-core_35.3.1-20230319081403_arm64.deb ...
sfdisk: /dev/nvme0n1: partition 1: failed to get partition name
dpkg: error processing archive /var/cache/apt/archives/nvidia-l4t-core_35.3.1-20230319081403_arm64.deb (--unpack):
 new nvidia-l4t-core package pre-installation script subprocess returned error exit status 1
E: Sub-process /usr/bin/dpkg returned an error code (1)
This workaround didn’t also work.
sudo rm  /var/cache/apt/archives/nvidia-l4t-core_35.3.1-20230319081403_arm64.deb
sudo apt --fix-broken install -o Dpkg::Options::="--force-overwrite"
I’ve decided to flush the SD card again. Don’t worry.
If it’s still not working, you can try with SDK manager to flash your device with JetPack. Thanks
