I am using Orbit with the GridCloner while enabling the “hydra scene-graph instancing” and “flatcache” using the following:
if sim.get_physics_context().use_gpu_pipeline:
sim.get_physics_context().enable_flatcache(True)
set_carb_setting(sim._settings,“/persistent/omnihydra/useSceneGraphInstancing”, True)
I get two sets of warnings while running the simulation from a standalone python script:
[Warning] [omni.hydra.scene_delegate.plugin] Calling getBypassRenderSkelMeshProcessing for prim /World/envs/env_0/table/leg_03.proto_leg_id0 that has not been populated
[Warning] [omni.usd] Coding Error: in _GetProtoPrim at line 1866 of /buildAgent/work/ca6c508eae419cf8/USD/pxr/usdImaging/usdImaging/instanceAdapter.cpp – Failed verification: ’ r ’ – instancer = /World/envs/env_0/kona_module/bolts/bolt_M5X16_tight, cachePath = /World/envs/env_0/kona_module/bolts/bolt_M5X16_tight
[Warning] [omni.usd] Coding Error: in ProcessPropertyChange at line 1313 of /buildAgent/work/ca6c508eae419cf8/USD/pxr/usdImaging/usdImaging/instanceAdapter.cpp – Failed verification: ’ proto.adapter ’ – /World/envs/env_0/kona_module/bolts/bolt_M5X16_tight
during scene loading
and/or
[Warning] [omni.hydra.scene_delegate.plugin] InstanceAdapter - cannot find cache item for proto /World/envs/env_0/kona_module/bolts/bolt_M5X16_tight.proto_bolt_M5X10_tight_id0
during the execution.
Interestingly, the second set of warnings depends on the cloned environment number; some numbers do not create the warning. When these warnings are there, I see undesired effects, such that I cannot set the pose of the prims, etc.
What do these warnings mean? How can I prevent them (and their effects)?
Note: Isaac Sim 2022.2.1 docker container on Ubuntu 20.04. Nvidia driver Version: 525.60.11. CUDA Version: 12.0.
Thanks in advance for the support.
