Ethernet issue when connected to Switch
Hey everyone
When I connect Jetson Nano to my wifi router using ethernet cable , I can access internet . But when I try using it on my switch connected to wifi router , I can ssh into the system but cannot access internet. Whereas other machine that is again connected the same switch in a different port can access the internet .
Am I missing something here
Is it correct that despite having some WiFi ability you are working entirely with wired? Also, are you rebooting the Nano after changing any wiring to/from a switch or router? Is it correct that a given switch port fails only on the Nano, but works in other cases? Have you rebooted the switch itself (cache can get in the way)?
Have done the rest , let me restart the switch and check
