Jetson Nano could not get an ip address
I have a Jetson Nano developer kit and I used internet via ethernet cable for months. 2-3 days ago I just connected my Jetson Nano with ethernet cable but it can not connect internet. My Jetson Nano device ethernet port leds (green and orange) is on and also using same ethernet cable with laptop, i can connect internet. I check my ip using terminal but i realized it can not take an any ip address. I have had the same problem for my other Jetson Nano device. I dont understand why is it doing, and how can i solve this problem without formatting sd card.
The IP is not decided by jetson. It is assigned by your ethernet switch.
You can share the dmesg first.
