through ethernet i am able to run ssh but when it comes to internet i am not. i have also setup my pc connection to share with all public networks.
in my pc ethernet network also shows unidentified network. earlier it also showed no internet access. but when i setup it up to share with all public network than it showed internet access. still cant see internet on my jetson nano . i have already looked at fourms but i cant get any help. please help.
What is the different here between your “ethernet” environment and “Internet” environment? Who is responsible for dhcp IP assign to jetson nano?
I feel you are asking a general computer networking problem but just this case today is on jetson nano. If you change jetson nano to another ubuntu device, then you may still hit same issue.
hello wayne, thanks for the response. i have just solved the problem. Actually the default gateway was not the ip address of my computer. however in my windows pc it still shows unidentified network but i am getting internet on my jetson nano.
using route command we can get see what is the default gateway and we can adjust it to our windows pc settings.
thanks for your reply again.
i appreciate it.
