Ethernet unstable connection / Packet-Loss (caused by EEE)
i whould like to add a comment to an already closed topic, so i post it here.
You can also disable EEE at runtime via “ethtool”: ethtool --set-eee eth0 eee off
So you dont have to recompile the Kernel.
Configuration by ethtool is not persistent over a reboot, so you have to execute the command in a boot-script.
best regards,
Matthias
You can disable EEE by adding this in kernel config.
→ CONFIG_EQOS_DISABLE_EEE
