if there is any option to export animation file from omniverse composer which is imported from flexsim
Where would you want to export it to ? It depends on a lot of factors. You are always best to “re-export from source”, so rather than going through Omniverse, you would be better off going straight from FlexSim to a popular 3D transport file format, like fbx.
You can try to simply open the usd file from Composer in other software. Or you can export it as an fbx from there. You just have to experiment with options.
