Hi all,
Im using external battery module for jetson nano B01 (4GB) module, but its not booting up from the battery module. Can someone please suggest if the battery module voltage & amp is sufficient or not ?
Hi all,
If you can boot nano with DC power supply, but failed with this battery, then it can tell the battery is insufficient.
Sure but what battery config do you suggest ?
We don’t have suggested battery, you can search in forum for other user’s suggestion. For power supply requests, please refer to the nano datasheet and design guide in DLC.
