Extremely Slow Loading Times - Isaac Sim 2023.1.0
I just installed Isaac Sim 2023.1.0, and am experiencing very slow loading times for the tutorials and when creating worlds. Loading the Franka example hangs for almost 5 minutes before the robot and room appear. Loading the simple room environment into a new stage also takes several minutes.
The computer I am using has a 32-core Threadripper with 256 GB of RAM and two 4090 GPUs, which I believe is more than sufficient for running the simulator. Will these slow loading times be typical for using Isaac Sim? The long waiting times are a bit of a pain, and I would love to shorten them if at all possible.
(I’m running Isaac Sim on Ubuntu 22.04. My NVIDIA driver version is 535.113.01.)
I had the same issue…the problem is server timeout settings… specifically you can launch a local nucleus server or alter the nucleus server code
please see explanation here
Thank you! Your solution worked for me–startup time is now under 10 seconds.
For those who come across this post later, the solution can be found at this link.
