Isaac Sim often gets stuck in my setup when I press the play button. The UI is unresponsive, and sometimes I see 1 or 2 CPU cores stuck at 100%. I have to kill it and restart. Any help appreciated.
The output on the console is this:
[Info] [carb] Logging to file: /home/ipm/.nvidia-omniverse/logs/Kit/Isaac-Sim/2021.1/kit_20211026_113017.log
[Info] [carb] Initializing plugin: carb.events.plugin (interfaces: [carb::events::IEvents v0.2]) (impl: carb.events.plugin)
[0.011s] Loading user config located at: ‘/home/ipm/.local/share/ov/data/Kit/Isaac-Sim/2021.1/user.config.json’
2021-10-26 09:30:17 [110ms] [Warning] [omni.ext.plugin] Extension with the same id is already registered. ext_id: ‘omni.kit.xr-1.0.0’, ext 1: ‘/home/ipm/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.xr’, ext 2: ‘/home/ipm/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.xr’
[0.128s] [ext: omni.usd.config-1.0.0] startup
[0.130s] [ext: omni.usd.libs-1.0.0] startup
[0.328s] [ext: omni.kit.pipapi-0.0.0] startup
[0.334s] [ext: omni.usd.schema.semantics-0.0.0] startup
[0.339s] [ext: omni.usd.schema.audio-0.0.0] startup
[0.342s] [ext: omni.hydra.iray-0.1.0] startup
[0.346s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.352s] [ext: omni.kit.async_engine-0.0.0] startup
[0.364s] [ext: omni.stats-0.0.0] startup
[0.366s] [ext: omni.assets.plugins-0.0.0] startup
[0.368s] [ext: omni.kit.loop-default-0.1.0] startup
[0.368s] [ext: omni.client-0.1.0] startup
[0.379s] [ext: omni.appwindow-1.0.0] startup
[0.395s] [ext: omni.kit.renderer.core-0.0.0] startup
| Driver Version: 470.63 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | GRID RTX8000-16Q | Yes | | 16630 MB | 10de | 0 |
| | | | | | 1e30 | 7a24b055… |
| 1 | GRID RTX8000-16Q | | | 16630 MB | 10de | 0 |
| | | | | | 1e30 | 7a24b055… |
| OS: Linux nvidia-omniverse-poc, Version: 5.4.0-87-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12008000 (1.20.8.0)
| Processor: Intel(R) Xeon(R) Gold 6240R CPU @ 2.40GHz | Cores: Unknown | Logical: 24
| Total Memory (MB): 128929 | Free Memory: 100982
| Total Page/Swap (MB): 979 | Free Page/Swap: 979
[1.474s] [ext: omni.kit.test-0.0.0] startup
[1.489s] [ext: omni.ui-2.1.8] startup
[1.508s] [ext: omni.kit.mainwindow-0.0.0] startup
[1.512s] [ext: omni.kit.uiapp-0.0.0] startup
[1.512s] [ext: omni.usd.schema.physics-1.0.0] startup
[1.520s] [ext: omni.usd.schema.isaac-0.1.0] startup
[1.543s] [ext: omni.usd.schema.anim-0.0.0] startup
[1.555s] [ext: omni.usd.schema.physx-0.0.0] startup
[1.576s] [ext: omni.kit.commands-0.0.0] startup
[1.581s] [ext: carb.audio-0.1.0] startup
[1.584s] [ext: omni.timeline-1.0.0] startup
[1.586s] [ext: omni.hydra.scene_delegate-0.1.0] startup
[1.597s] [ext: omni.usd-1.4.2] startup
[1.626s] [ext: omni.kit.menu.utils-1.0.1] startup
[1.637s] [ext: omni.kit.material.library-1.0.4] startup
[1.647s] [ext: omni.kit.menu.create-1.0.1] startup
[1.650s] [ext: omni.kit.context_menu-1.1.0] startup
[1.756s] [ext: omni.services.facilities.base-1.0.0] startup
[1.759s] [ext: omni.kit.widget.path_field-2.0.2] startup
[1.764s] [ext: omni.services.core-1.1.0] startup
[1.897s] [ext: omni.kit.widget.browser_bar-2.0.1] startup
[1.901s] [ext: omni.kit.window.popup_dialog-2.0.0] startup
[1.906s] [ext: omni.kit.widget.stage-2.4.0] startup
[1.913s] [ext: omni.services.transport.client.base-1.0.0] startup
[1.916s] [ext: omni.services.transport.server.base-1.0.0] startup
[1.919s] [ext: omni.kit.search_core-1.0.0] startup
[1.924s] [ext: omni.services.client-0.2.0] startup
[1.951s] [ext: omni.services.transport.server.http-1.0.0] startup
[2.016s] [ext: omni.kit.notification_manager-1.0.0] startup
[2.021s] [ext: omni.kit.widget.filebrowser-2.2.4] startup
[2.030s] [ext: omni.services.transport.client.http_async-1.0.0] startup
[2.189s] [ext: omni.kit.agent-0.1.0] startup
[2.193s] [ext: omni.kit.window.drop_support-1.0.0] startup
[2.197s] [ext: omni.kit.thumbnails.images-0.1.1] startup
[2.203s] [ext: omni.kit.stage_templates-1.0.4] startup
[2.209s] [ext: omni.kit.window.filepicker-2.3.1] startup
[2.265s] [ext: omni.renderer-rtx-0.0.0] startup
[2.266s] [ext: omni.kit.renderer.capture-0.0.0] startup
[2.272s] [ext: omni.hydra.rtx-0.1.0] startup
[2.276s] [ext: omni.kit.window.file-1.2.2] startup
[2.332s] [ext: omni.kit.window.property-0.0.0] startup
[2.338s] [ext: omni.kit.window.viewport-0.0.0] startup
2021-10-26 09:30:19 [2,332ms] [Warning] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0] ‘/home/ipm/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/rtx/rtx.reshade.plugin’ in ‘[[native.plugin]]’ was not found.
2021-10-26 09:30:20 [3,379ms] [Warning] [carb] Acquiring non optional plugin interface which is not listed as dependency: [rtx::raytracing::Subsurface v0.1] (plugin: rtx.raytracing.plugin), by client: carb.scenerenderer-rtx.plugin. Add it to CARB_PLUGIN_IMPL_DEPS() macro of a client.
[3.751s] [ext: omni.kit.window.content_browser-2.3.1] startup
[3.791s] [ext: omni.kit.property.usd-3.9.4] startup
[3.815s] [ext: omni.kit.thumbnails.usd-0.3.0] startup
[3.853s] [ext: omni.kit.property.geometry-1.1.0] startup
[3.860s] [ext: omni.kvdb-0.0.0] startup
[3.865s] [ext: omni.kit.widget.layers-1.5.2] startup
[3.883s] [ext: omni.kit.property.light-1.0.4] startup
[3.889s] [ext: omni.kit.property.camera-1.0.3] startup
[3.895s] [ext: omni.localcache-0.0.0] startup
[3.900s] [ext: omni.usdphysics-1.2.0] startup
[3.901s] [ext: omni.kit.property.layer-1.1.0] startup
[3.909s] [ext: omni.kit.usd_undo-0.1.0] startup
[3.914s] [ext: omni.kit.property.audio-1.0.4] startup
[3.921s] [ext: omni.kit.property.transform-1.0.2] startup
[3.931s] [ext: omni.kit.property.material-1.6.4] startup
[3.941s] [ext: omni.convexdecomposition-1.2.0] startup
[3.948s] [ext: omni.kit.property.bundle-1.2.4] startup
[3.955s] [ext: omni.ansel-0.2.0] startup
2021-10-26 09:30:21 [3,944ms] [Warning] [omni.ext.plugin] [ext: omni.ansel-0.2.0] Failed to load plugins, folder doesn’t exist: ‘/home/ipm/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.ansel/bin’.
2021-10-26 09:30:21 [3,944ms] [Warning] [omni.ext.plugin] [ext: omni.ansel-0.2.0] ‘/home/ipm/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.ansel/bin/*.plugin’ in ‘[[native.plugin]]’ was not found.
[3.959s] [ext: omni.kit.numpy.common-0.1.0] startup
[4.064s] [ext: omni.kit.window.toolbar-1.0.0] startup
[4.077s] [ext: omni.physx-1.2.0-5.1] startup
[4.108s] [ext: omni.debugdraw-0.0.0] startup
[4.115s] [ext: omni.isaac.dynamic_control-0.1.3] startup
[4.127s] [ext: omni.syntheticdata-0.1.5] startup
[4.245s] [ext: omni.isaac.ros_bridge_ui-0.1.0] startup
[4.252s] [ext: omni.isaac.utils-0.1.4] startup
[4.266s] [ext: omni.isaac.range_sensor-0.1.2] startup
[4.279s] [ext: omni.kit.widget.settings-1.0.0] startup
[4.288s] [ext: omni.isaac.ros_bridge-0.1.0] startup
Checking if ROS_MASTER_URI is set:
Found ROS_MASTER_URI= http://192.168.0.2:11311/
[4.388s] [ext: omni.physx.commands-1.0.0] startup
[4.393s] [ext: omni.kit.asset_converter-1.1.22] startup
[4.416s] [ext: omni.kit.window.preferences-1.1.1] startup
[4.459s] [ext: omni.physx.ui-1.2.0-5.1] startup
[4.478s] [ext: omni.isaac.shapenet-1.0.0] startup
env var SHAPENET_LOCAL_DIR not set, using default data dir /home/ipm/.local/share/ov/data/Kit/Isaac-Sim/2021.1/shapenet
omni.isaac.shapenet’s receiver for external messages has started. on (‘localhost’, ‘7011’)
[4.535s] [ext: omni.isaac.urdf-0.1.4] startup
[4.551s] [ext: omni.isaac.synthetic_utils-0.1.0] startup
[4.560s] [ext: omni.physx.demos-1.0.0] startup
[4.566s] [ext: omni.kit.tool.asset_importer-2.3.2] startup
[4.577s] [ext: omni.isaac.motion_planning-0.1.4] startup
[4.590s] [ext: omni.isaac.robot_engine_bridge_ui-0.1.0] startup
[4.598s] [ext: omni.kit.property.physx-0.1.0] startup
[4.666s] [ext: omni.isaac.manip-0.1.2] startup
[4.680s] [ext: omni.isaac.robot_engine_bridge-0.1.0] startup
[5.032s] [ext: omni.physx.vehicle-1.2.0-5.1] startup
[5.053s] [ext: omni.isaac.step_importer-0.1.1] startup
[5.128s] [ext: omni.kit.menu.file-1.0.2] startup
[5.137s] [ext: omni.isaac.samples-0.1.6] startup
[5.167s] [ext: omni.kit.tool.collect-2.0.1] startup
[5.180s] [ext: omni.isaac.window.about-1.0.0] startup
[5.189s] [ext: omni.isaac.utils_manager-0.1.0] startup
[5.198s] [ext: omni.isaac.dr-0.1.6] startup
[5.210s] [ext: omni.graph.core-1.0.0] startup
[5.214s] [ext: omni.graph.tools-1.0.0] startup
[5.229s] [ext: omni.kit.widget.fast_search-0.3.0] startup
[5.238s] [ext: omni.kit.widget.graph-1.1.2] startup
[5.251s] [ext: omni.graph-1.0.0] startup
[5.312s] [ext: omni.kit.primitive.mesh-1.0.0] startup
[5.323s] [ext: omni.kit.window.tests-0.1.0] startup
[5.427s] [ext: omni.physx.cct-1.2.0-5.1] startup
[5.438s] [ext: omni.command.usd-1.0.1] startup
[5.445s] [ext: omni.graph.ui-1.0.1] startup
[5.519s] [ext: omni.isaac.tests-0.0.0] startup
[5.528s] [ext: omni.physx.bundle-1.2.0-5.1] startup
[5.528s] [ext: omni.kit.tagging-0.1.0] startup
[5.614s] [ext: omni.kit.menu.edit-1.0.3] startup
[5.624s] [ext: omni.kit.menu.select-1.0.0] startup
[5.644s] [ext: omni.kit.window.extensions-1.0.2] startup
[5.658s] [ext: omni.graph.examples.python-1.0.0] startup
[5.795s] [ext: omni.kit.filebrowser_column.tags-1.0.0] startup
[5.805s] [ext: omni.kit.widget.stage_icons-1.0.1] startup
[5.816s] [ext: omni.kit.property.isaac-0.1.0] startup
[5.826s] [ext: omni.isaac.contact_sensor-0.1.0] startup
[5.839s] [ext: omni.kit.window.console-0.0.0] startup
[5.843s] [ext: omni.kit.window.profiler-1.0.0] startup
[5.853s] [ext: omni.kit.window.stage-2.3.3] startup
[5.866s] [ext: omni.kit.widget.prompt-1.0.0] startup
[5.876s] [ext: omni.kit.widget.live-0.0.0] startup
[5.878s] [ext: omni.kit.widget.imageview-1.0.0] startup
[5.889s] [ext: omni.kit.window.cursor-1.0.1] startup
[5.902s] [ext: omni.kit.window.status_bar-0.0.0] startup
[5.903s] [ext: omni.rtx.window.settings-0.6.0] startup
[5.913s] [ext: omni.kit.window.usd_paths-1.0.3] startup
[5.924s] [ext: omni.videoencoding-0.0.0] startup
[5.928s] [ext: semantics.schema.editor-0.1.3] startup
[5.931s] [ext: omni.kit.window.imageviewer-1.0.3] startup
[5.945s] [ext: omni.kit.widget.sliderbar-1.0.3] startup
[5.956s] [ext: omni.rtx.settings.core-0.5.4] startup
[5.968s] [ext: omni.iray.settings.core-0.6.2] startup
[5.978s] [ext: omni.kit.capture-0.4.0] startup
[5.991s] [ext: omni.kit.window.title-1.1.0] startup
[6.002s] [ext: omni.kit.selection-0.0.0] startup
[6.012s] [ext: omni.kit.search.service-0.1.0] startup
[6.026s] [ext: omni.kit.window.commands-0.1.1] startup
[6.038s] [ext: omni.kit.window.script_editor-1.5.0] startup
[6.039s] [ext: omni.kit.window.movie_maker-0.4.9] startup
[6.053s] [ext: omni.isaac.occupancy_map-0.1.0] startup
[6.068s] [ext: omni.kit.window.stats-0.0.0] startup
[6.080s] [ext: omni.isaac.app.setup-0.0.0] startup
[6.090s] [ext: omni.isaac.sim.base-2021.1.1] startup
[6.090s] [ext: omni.isaac.sim-2021.1.1] startup
[6.090s] app started
2021-10-26 09:30:23 [6,107ms] [Warning] [omni.ext-live.plugin] Omniverse Cache is disabled! It can be turned on in Omniverse System Monitor.
Isaac Sim App is loaded.
Checking for Isaac Sim assets on nucleus server
Check successful
2021-10-26 09:40:55 [638,526ms] [Error] [omni.physx.plugin] PhysX error: GPU solveSelfConstraints fail to launch kernel!!
, FILE /buildAgent/work/e9422d924067f9fc/source/gpuarticulation/src/PxgArticulationCore.cpp, LINE 982
2021-10-26 09:40:55 [638,526ms] [Error] [omni.physx.plugin] PhysX error: GPU artiSolveInternalTendonConstraints1T fail to launch kernel!!
, FILE /buildAgent/work/e9422d924067f9fc/source/gpuarticulation/src/PxgArticulationCore.cpp, LINE 1002
2021-10-26 09:40:55 [638,526ms] [Error] [omni.physx.plugin] PhysX error: GPU solveInternalConstraints fail to launch kernel!!
, FILE /buildAgent/work/e9422d924067f9fc/source/gpuarticulation/src/PxgArticulationCore.cpp, LINE 1031
2021-10-26 09:40:55 [638,527ms] [Error] [omni.physx.plugin] PhysX error: GPU solveInternalConstraints fail to launch kernel!!
2021-10-26 09:40:55 [638,527ms] [Error] [omni.physx.plugin] PhysX error: GPU solveSelfConstraints fail to launch kernel!!
2021-10-26 09:40:55 [638,527ms] [Error] [omni.physx.plugin] PhysX error: GPU artiSolveInternalTendonConstraints1T fail to launch kernel!!
2021-10-26 09:40:55 [638,528ms] [Error] [omni.physx.plugin] PhysX error: GPU solveSelfConstraints fail to launch kernel!!
2021-10-26 09:40:55 [638,528ms] [Error] [omni.physx.plugin] PhysX error: GPU artiSolveInternalTendonConstraints1T fail to launch kernel!!
2021-10-26 09:40:55 [638,528ms] [Error] [omni.physx.plugin] PhysX error: GPU solveInternalConstraints fail to launch kernel!!
2021-10-26 09:40:55 [638,528ms] [Error] [omni.physx.plugin] PhysX error: GPU concludeBlockFunction fail to launch kernel!!
, FILE /buildAgent/work/e9422d924067f9fc/source/gpusolver/src/PxgCudaSolverCore.cpp, LINE 1685
2021-10-26 09:40:55 [638,528ms] [Error] [omni.physx.plugin] PhysX error: GPU artiSaveVelocitiesFunction fail to launch kernel!!
, FILE /buildAgent/work/e9422d924067f9fc/source/gpuarticulation/src/PxgArticulationCore.cpp, LINE 908
2021-10-26 09:40:55 [638,528ms] [Error] [omni.physx.plugin] PhysX error: GPU mWritebackBlockFunction fail to launch kernel!!
, FILE /buildAgent/work/e9422d924067f9fc/source/gpusolver/src/PxgCudaSolverCore.cpp, LINE 1912
2021-10-26 09:40:55 [638,528ms] [Error] [omni.physx.plugin] PhysX error: SynchronizeStreams failed
, FILE /buildAgent/work/e9422d924067f9fc/source/gpucommon/include/PxgCudaUtils.h, LINE 79
