Specs:
Platform: DRIVE AGX Xavier
Driveworks: 4.0.0
DriveOS: 5.2.6
Hey there, I wanted to switch from the pinhole
model to ftheta
When using the pinhole model everything works but when switching to the F-Theta model I get the following error message. Terminating app due to unexpected exception: DW_FAILURE: FThetaCamera: derivative of distortion within image interior (including edge) is negative
When using the FTheta Model I was implementing the parameters as described in this thread: Ftheta model parameters → j_0=0, j_1= inverse of the focal length, j_2,j_3= radial distortion coefficients, j_4, j_5= tangential distortion coefficients
"constraints": [],
"focalLengthPixel": [
981.817474,
979.962902
"image-size": [
1936,
1216
"model": {
"center": [
966.461471,
602.120647
"bw-poly": [
0.0,
-0.001018519,
-0.00190517,
-0.0277921,
0.0173957
"focal": [
981.817474,
979.962902
"fov": 1.5566234691909453,
"image-size": [
1936,
1216
"is-model-fixed": true,
"name": "back",
"type": "ftheta"
"name": "back",
"type": "ftheta"
Unfortunately I couldn’t find any sample files or explanations on how these files should be build. Therefore I have the following questions:
What does
define? -
Is this
"focalLengthPixel": [fx, fy]"
the right way of usingfocalLengthPixel
What does
image-size
define when it is mentioned outside of the model definition and what does it describe in the model definition?
