Hello team. I am using Xavier DRIVE kit, got system no longer display anything from HDMI to the monitor after forced shutdown. Just because when I installed nvidia-jetpack using sudo apt-get install nvidia-jetpack the terminal got halted. Is there button for factory reset or how to recover from this situation? Thanks
The DRIVE hardware is different than Jetson. Some of it is shared, but you can’t use the regular Jetson software with your hardware. You are probably needing to move this post to:
https://forums.developer.nvidia.com/c/autonomous-vehicles/drive-agx/57
My guess is that you will need to flash your system again due to the Jetson software which differs from the DRIVE version.
Thank you.
