Hi guys! I try to upgrade my SDK from r35.5.0 to r36.4, but I failed with following error in debug serial:
ERROR: Exception reason=0 syndrome=0xbe000011
ERROR: **************************************
ERROR: RAS Uncorrectable Error in IOB, base=0xe010000:
ERROR: Status = 0xec000612
ERROR: SERR = Error response from slave: 0x12
ERROR: IERR = CBB Interface Error: 0x6
ERROR: Overflow (there may be more errors) - Uncorrectable
ERROR: MISC0 = 0xc4560040
ERROR: MISC1 = 0x1a4c860000000000
ERROR: MISC2 = 0x0
ERROR: MISC3 = 0x0
ERROR: ADDR = 0x8000000003f300c0
ERROR: sdei_dispatch_event returned -1
ERROR: RAS Uncorrectable Error in ACI, base=0xe01a000:
ERROR: Status = 0xe8000904
ERROR: SERR = Assertion failure: 0x4
ERROR: IERR = FillWrite Error: 0x9
ERROR: Powering off core
I’ve check the stmm_sp.c. The stmm_heap_size has been changed from 512 to 1024 in r36.4, which should be modified in r35.5.0.
Could you guys help me to fix the problem?
My flash environment:
- Customized board (we do not have devkit)
- SDK version: r36.4
- host system: Arch Linux
Here is the flash_command.log (290.8 KB) and debug_serial.log (48.7 KB) in which the flash command is
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
-c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
--showlogs --network usb0 nano-usb-client external
And here is our flash config and device tree
// nano-usb-client.conf
source "${LDK_DIR}/jetson-orin-nano-devkit.conf";
PINMUX_CONFIG="tegra234-mb1-bct-pinmux-p3767-hdmi-a03.dtsi"; # hdmi
PMC_CONFIG="tegra234-mb1-bct-padvoltage-p3767-hdmi-a03.dtsi"; # hdmi
EMMC_CFG="flash_t234_qspi_nvme.xml";
UPHYLANE="c7x2"
if [ "${UPHYLANE}" = "c7x1" ]; then
UPHYLANE_CONFIG="tegra234-mb1-bct-uphylane-si-c7x1.dtsi";
EMMC_CFG="flash_t234_qspi_nvme_c7.xml";
elif [ "${UPHYLANE}" = "c7x2" ]; then
UPHYLANE_CONFIG="tegra234-mb1-bct-uphylane-si-c7x2.dtsi";
fi
update_flash_args()
# All updates should go into update_flash_args_common to allow
# for other files to include this file and override variables.
update_flash_args_common "$@"
if [ "${board_sku}" = "0001" ]; then
DTB_FILE="kenexs-v700-usb-client.dtb";
elif [ "${board_sku}" = "0003" ]; then
DTB_FILE="kenexs-v700-nano-usb-client.dtb";
else
echo "Error: Unrecognized module SKU ${board_sku}";
exit 1;
fi
TBCDTB_FILE="${DTB_FILE}";
// kenexs-v700-nano-usb-client.dts
/dts-v1/;
#include "../nv-platform/tegra234-p3768-0000+p3767-0003-nv.dts"
display@13800000 {
status = "okay";
os_gpio_hotplug_a = <&gpio TEGRA234_MAIN_GPIO(M, 0) GPIO_ACTIVE_HIGH>;
bus@0 {
/* C1 - PCIe1 GigE RTL8111H */
pcie@14100000 {
status = "okay";
/* C7 - PCIe2 M.2 Key-M */
pcie@141e0000 {
status = "okay";
vddio-pex-ctl-supply = <&vdd_1v8_ao>;
phys = <&p2u_gbe_0>;
phy-names = "p2u-0";
/* C9 - PCIe3 GigE RTL8111H */
pcie@140c0000 {
status = "okay";
phys = <&p2u_gbe_1>;
phy-names = "p2u-1";
/* enable usb 3-2: padctl node */
padctl@3520000 {
pads {
usb3 {
lanes {
usb3-2 {
nvidia,function = "xusb";
status = "okay";
ports {
usb3-0 {
nvidia,usb2-companion = <2>;
status = "okay";
usb3-1 {
nvidia,usb2-companion = <1>;
status = "okay";
usb3-2 {
nvidia,usb2-companion = <0>;
status = "okay";
/* enable usb 3-2: xHCI Node */
usb@3610000 {
status = "okay";
phys = <&{/bus@0/padctl@3520000/pads/usb2/lanes/usb2-0}>,
<&{/bus@0/padctl@3520000/pads/usb2/lanes/usb2-1}>,
<&{/bus@0/padctl@3520000/pads/usb2/lanes/usb2-2}>,
<&{/bus@0/padctl@3520000/pads/usb3/lanes/usb3-0}>,
<&{/bus@0/padctl@3520000/pads/usb3/lanes/usb3-1}>,
<&{/bus@0/padctl@3520000/pads/usb3/lanes/usb3-2}>;
phy-names = "usb2-0", "usb2-1", "usb2-2", "usb3-0",
"usb3-1", "usb3-2";
//xudc@3550000 {
usb@3550000 {
status = "okay";
phy-names = "usb2-0", "usb3-2";
nvidia,xusb-padctl = <&xusb_padctl>;
status = "disabled"; // as otg is disabled in usb2-0, so here disable it
model = "KENEXS V700 NANO USB UDC flash";
//tegra_xudc:
//xudc@3550000 {
usb@3550000 {
status = "okay";
//xusb_padctl@3520000 {
padctl@3520000{
ports {
usb2-0 {/* Goes to recovery port */
mode = "otg";
bus@0 {
/* C4 - PCIe0 10GigE AQC113-B1-I */
pcie@14160000 {
