Help, I am trying to flash the Jetson Orin Nano with JP 5.2.1 using the SDK. I had tried previously with the flash.sh command but kept receiving the error “No devices to flash”. I have attached the log from the SDKManager flash attempt.
I have tried multiple machines running Ubuntu 20.04 natively, multiple usb cables, multiple sd cards and yes the board is in recovery mode.
I have had success with multiple other Orin Nano boards but this is the only one that has failed to flash.
Error: Invalid argument during seek for read on /dev/mmcblk1
[ 9]: l4t_flash_from_kernel: Error: partprobe failed. This indicates that:
- the xml indicates the gpt is larger than the device storage
- the xml might be invalid
- the device might have a problem.
Please make correction.
Note: This did not work with any 64GB SD cards I had tried. Recommendation is to get at least a 128 SD card. Its 2024 why don’t we all have 1TB SD cards lying around anyway?
