Isaac Sim Version 4.5.0
Operating System Windows 10
GPU Information
- Model: RTX 2060
- Driver Version: 572.70
Topic Description
Detailed Description
I tried to creating an empty scene by first clicking “python.bat” and type import isaacsim then type isaaclab, then paste codes for creating an empty scene, which is:
import argparse
from isaaclab.app import AppLauncher
parser = argparse.ArgumentParser(description=“Tutorial on creating an empty stage.”)
AppLauncher.add_app_launcher_args(parser)
args_cli = parser.parse_args()
app_launcher = AppLauncher(args_cli)
simulation_app = app_launcher.app
Error Messages
2025-03-11 15:52:51 [9,406ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module isaaclab_rl. Error: No module named ‘rsl_rl’. Traceback:
File “D:\Isaac sim\Isaacsim/kit/kernel/py\omni\ext_impl\custom_importer.py”, line 76, in import_module
return importlib.import_module(name)
File "D:\Isaac sim\Isaacsim\kit\python\lib\importlib_init.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1050, in _gcd_import
File “”, line 1027, in _find_and_load
File “”, line 1006, in _find_and_load_unlocked
File “”, line 688, in _load_unlocked
File “”, line 883, in exec_module
File “”, line 241, in _call_with_frames_removed
File “d:/isaac sim/isaacsim/kit/python/lib/site-packages/isaaclab/source/isaaclab_rl/isaaclab_rl/init.py”, line 21, in
from . import rl_games, rsl_rl, sb3, skrl
File “d:/isaac sim/isaacsim/kit/python/lib/site-packages/isaaclab/source/isaaclab_rl/isaaclab_rl/rsl_rl/init.py”, line 20, in
from .vecenv_wrapper import RslRlVecEnvWrapper
File “d:/isaac sim/isaacsim/kit/python/lib/site-packages/isaaclab/source/isaaclab_rl/isaaclab_rl/rsl_rl/vecenv_wrapper.py”, line 9, in
from rsl_rl.env import VecEnv
ModuleNotFoundError: No module named ‘rsl_rl’
2025-03-11 15:52:51 [9,407ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaaclab_rl’ in ‘d:\isaac sim\isaacsim\kit\python\lib\site-packages\isaaclab\source\isaaclab_rl’ failed to load.
At:
D:\Isaac sim\Isaacsim/kit/kernel/py\omni\ext_impl_internal.py(213): startup
D:\Isaac sim\Isaacsim/kit/kernel/py\omni\ext_impl_internal.py(328): startup_extension
PythonExtension.cpp::startup()(2):
D:\Isaac sim\Isaacsim\exts\isaacsim.simulation_app\isaacsim\simulation_app\simulation_app.py(427): _start_app
D:\Isaac sim\Isaacsim\exts\isaacsim.simulation_app\isaacsim\simulation_app\simulation_app.py(212): init
D:\Isaac sim\Isaacsim\kit\python\Lib\site-packages\isaaclab\source\isaaclab\isaaclab\app\app_launcher.py(642): _create_app
D:\Isaac sim\Isaacsim\kit\python\Lib\site-packages\isaaclab\source\isaaclab\isaaclab\app\app_launcher.py(114): init
(1):
2025-03-11 15:52:51 [9,407ms] [Error] [omni.ext.plugin] [ext: isaaclab_rl-0.1.0] Failed to startup python extension.
Screenshots or Videos
I am not sure is this because RTX2060 is too low to run isaac sim4.5.0. Or I have to change a laptop such RTX4060 to run it.
