Simulation App Starting
Simulation App Startup Complete
2022-07-01 10:29:45 [20,226ms] [Warning] [omni.hydra.scene_delegate.plugin] Calling setBypassRenderSkelMeshProcessing for prim /jetbot/right_wheel that is not usdskel mesh type
2022-07-01 10:29:45 [20,627ms] [Warning] [gpu.foundation.plugin] Requesting texture to use texture streaming, but the service isn’t available.The texture will be created as a regular resource.
2022-07-01 10:29:58 [33,440ms] [Warning] [omni.client.plugin] Tick: provider_nucleus: Null result for omni1ReadAssetVersion(omniverse://localhost/Isaac/Environments/Grid/Materials/Textures/radialGrid_clrmap_50.png): LFT failure
2022-07-01 10:29:58 [33,440ms] [Warning] [carb.assets.plugin] Asset load of omniverse://localhost/Isaac/Environments/Grid/Materials/Textures/radialGrid_clrmap_50.png failed with Response 1
2022-07-01 10:29:58 [33,440ms] [Error] [gpu.foundation.plugin] Failed to load texture omniverse://localhost/Isaac/Environments/Grid/Materials/Textures/radialGrid_clrmap_50.png
2022-07-01 10:29:58 [33,625ms] [Warning] [omni.client.plugin] Tick: provider_nucleus: Null result for omni1ReadAssetVersion(omniverse://localhost/Isaac/Environments/Grid/Materials/Textures/radialFalloffGrid_v02.png): LFT failure
2022-07-01 10:29:58 [33,625ms] [Warning] [carb.assets.plugin] Asset load of omniverse://localhost/Isaac/Environments/Grid/Materials/Textures/radialFalloffGrid_v02.png failed with Response 1
2022-07-01 10:29:58 [33,625ms] [Error] [gpu.foundation.plugin] Failed to load texture omniverse://localhost/Isaac/Environments/Grid/Materials/Textures/radialFalloffGrid_v02.png
![Screenshot from 2022-07-01 18-37-46|690x332](upload://gnRyumO8tMADWc8xQshEDiWLfLx.png
when I Stop the Cache ,it works. But it takes a lot of time to load
2022-07-01 12:49:34 [33,019ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/Isaac/Environments/Office/Materials/MI_Blinds_transp.mdl(29,2): C188 annotation ‘distill_off’ will be ignored
2022-07-01 12:49:34 [33,019ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/Isaac/Environments/Office/Materials/MI_Blinds_transp.mdl(44,8): C181 unused variable ‘Local5’
2022-07-01 12:49:34 [33,332ms] [Warning] [omni.ext-live.plugin] Omniverse Cache is disabled! It can be turned on in Omniverse System Monitor.
2022-07-01 12:49:34 [33,375ms] [Warning] [gpu.foundation.plugin] Requesting texture to use texture streaming, but the service isn’t available.The texture will be created as a regular resource.
