Failed to use isaac_ros_argus_camera with JetPack 6.2
We are trying to setup IsaacRos 3.2 in JetPack 6.2.
However we found that argus camera node failed to start with imx219, the process end with the message:
[ERROR] [component_container_mt-1]: process has died [pid 2310, exit code -11, cmd ‘/opt/ros/humble/lib/rclcpp_components/component_container_mt --ros-args --log-level info --ros-args -r __node:=argus_mono_container -r __ns:=/’].
We confirmed that this is not hardware problem as the same set of hardware working with JetPack 6.1, 6.0
May I know how can we fix this?
Same behavior with the same camera(s)+Isaac+Jetpack, which also mostly worked with Jetpack 6.1. Following.
Hi, I’m forwarding this issue to the engineering.
I keep you posted.
Raffaello
