okay, how can i make a livefeed of the stream?
hello aranis.das,
please check developer guide for sample pipelines, Accelerated GStreamer.
or, you may revise that functional 1080p gst pipeline for display rendering.
for example,
$ export DISPLAY=:0
$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920, height=1080, framerate=21/1, format=NV12' ! nvoverlaysink -ev
gudboy007@ubuntubox:~$ export DISPLAY=:0
gudboy007@ubuntubox:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM),width=1920, height=1080, framerate=21/1, format=NV12’ ! nvoverlaysink -ev
No protocol specified
nvbuf_utils: Could not get EGL display connection
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)21/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)21/1
/GstPipeline:pipeline0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)21/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)21/1
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
I got this, but there is no active video feed
there’s error about EGL display. please check your display settings.
you may also checking with xrandr,
it should report all monitor supported resolution if you’ve configure display setting correctly,
for example,
$ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 480mm x 270mm
1920x1080 60.00*+ 59.95 50.00 30.00 29.97
1680x1050 59.96
1440x900 59.89
1280x1024 60.00
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 70.07 60.01
800x600 60.32 56.25
720x576 50.00
720x480 59.94
720x400 70.04
640x480 67.06 59.94 59.94
gudboy007@ubuntubox:~$ xrandr
Screen 0: minimum 256 x 256, current 1400 x 1050, maximum 16384 x 16384
rdp0 connected 1400x1050+0+0 0mm x 0mm
1400x1050 50.00*
hello aranis.das,
it looks your display monitor doesn’t support with 1920x1080 resolution.
hence, please add video converter to download the frame to adapt your monitor.
you may refer to below.
$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920, height=1080, framerate=21/1, format=NV12' ! nvvidconv ! 'video/x-raw(memory:NVMM), format=(string)NV12, width=640, height=480' ! nvoverlaysink -ev
So i ran this:
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, format=NV12, framerate=30/1’ ! nvvidconv ! videoconvert ! xvimagesink
and it finally showed something, but the output was absolutely horrible and looked like the camera output is underwater. Unusable for any opencv. I tried upping the resolution but it wouldn’t run, but I did test both the cameras and they both were the same terrible quality.
what is causing this? is there a better way to test my camera?
gudboy007@ubuntubox:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM),width=1920, height=1080, framerate=21/1, format=NV12’ ! nvvidconv ! ‘video/x-raw(memory:NVMM), format=(string)NV12, width=640, height=480’ ! nvoverlaysink -ev
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, framerate=(fraction)21/1, format=(string)NV12, pixel-aspect-ratio=(fraction)4/3
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, framerate=(fraction)21/1, format=(string)NV12, pixel-aspect-ratio=(fraction)4/3
/GstPipeline:pipeline0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, framerate=(fraction)21/1, format=(string)NV12, pixel-aspect-ratio=(fraction)4/3
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, framerate=(fraction)21/1, format=(string)NV12, pixel-aspect-ratio=(fraction)4/3
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)21/1
Camera index = 0
Camera mode = 2
seconds to Run = 0
It does not open the window
we’ve confirmed you’re able to get the output the stream via v4l standard IOCTL and gst pipeline.
the failure… nvbuf_utils: Could not get EGL display connection it’s more like a display issue.
since you’ve initial a new thread, let’s following-up there, Topic 264699.
