Broken multi-fan control on GeForce RTX 4090 (Gigabyte, 3-fan): fan:1 never driven, and an unenumerated 3rd fan runs at max and never stops.
Summary
On a 3-fan Gigabyte RTX 4090 (AD102), the Linux driver enumerates only 2 fans and mismanages the card in two distinct ways. Both work correctly on Windows with the same board/VBIOS, so this is a Linux driver / GSP-RM fan-control defect, not hardware.
- Middle fan is never driven. Enumerated as fan:1; GPUTargetFanSpeed assignments are accepted, but GPUCurrentFanSpeed stays 0 and it never spins, even under load at 90 Β°C.
- A third physical fan is not enumerated and is mishandled by GSPβs automatic policy: driven to 100% on spin-up, then neglected (left at 100%) on spin-down, so it stays at max indefinitely. Only a full power cycle (S3/shutdown) resets it, a warm reboot does not.
Environment
β GPU β GeForce RTX 4090 (AD102), 10de:2684 rev a1, GPU part 2684-301-A1
β Card β Gigabyte 3-fan RTX 4090
β VBIOS β 95.02.3C.80.B0
β Driver β 610.43.02 (proprietary, dkms)
β GSP β enabled (GPU Firmware: 610.43.02)
β Kernel β 6.8.0-124-generic
β Distro β Ubuntu 24.04.4 LTS
β Also reproduces β driver 400.x / 500.x (565/575/590) β not a recent regression
Bug Report Log
nvidia-bug-report.log.gz (653.1 KB)
nvidia-settings -q fans
2 Fans on mpc:1
[0] mpc:1[fan:0] (Fan 0)
Has the following name:
FAN-0
[1] mpc:1[fan:1] (Fan 1)
FAN-1
I was able to observe this behavior ever since version 450, and on all drivers up-to 610.
Observed behavior
nvidia-settings -q fans β 2 Fans though the card has 3.
- fan:0 (rightmost): works (target honored, current tracks).
- fan:1 (middle): enumerated but dead: targets accepted, GPUCurrentFanSpeed stays 0, never spins at 30/50/100 or at 90Β°C.
- Third fan (leftmost, unenumerated): latched at 100% by auto policy on spin-up, never spun down; only a power cycle resets it (warm reboot does not).
Investigated / ruled out
- Manual control (GPUFanControlState=1) reaches only fan:0, but canβt drive fan:1 or the third fan.
- Disabling GSP (NVreg_EnableGpuFirmware=0) leaves third fan still stuck, and middle still not driven (worse).
- No IΒ²C fan MCU on GPU buses (only monitor EDID).
- BAR0 inspection (THERM 0x20000, PMGR 0x10000, GC6/SCI 0x118000): only measurement registers track the third/middle fans (tach 0x2160c, SCI 0x118ac8), with no host-writable duty register, and with PWM drive being GSP-internal. Writing measurement/status regs doesnβt move the fan.
- VBIOS: fan/cooler tables present; GPIO map shows a single FAN_PWM (GPIO 16) + single FAN_TACH (GPIO 13).
Comparison to Windows
Same board/VBIOS: Windows (driver + NVAPI clients like Afterburner) drives all three fans correctly. The divergence is in how the Linux driver/GSP-RM parses the fan cooler table and sets up per-fan PWM/tach/GPIO mappings at init, not in the set-speed path.
Impact
Middle fan never runs on Linux causing ineffective cooling due to bad airflow distribution; third fan runs at 100% on an idle desktop until a power cycle (noise, wear, power).
Reproduction
- Boot Linux, driver 610.43.02, 3-fan Gigabyte RTX 4090.
- nvidia-settings -q fans β only 2 fans.
- nvidia-settings -a β[gpu:0]/GPUFanControlState=1β -a β[fan:1]/GPUTargetFanSpeed=100β β fan:1 current stays 0; middle fan doesnβt spin.
- Load GPU until fans spin, return to idle β third fan stays at 100%; only suspend/shutdown resets it.
I hope nvidia can fix the fan cooler/thermal table parsing and per-fan PWM/tach/GPIO mapping for this 3-fan board so fan:1 is actually driven and all fans are in both the spin-up and spin-down paths, or expose a way for me to handle it. If a registry key (RmFan2XOverride, RMDisableThermOnlyGpio) can force correct enumeration/mapping in the interim, please advise.
