Fedora 5.7.8-200.fc32.x86_64 / Nvidia 450.57 / Unable to load nvidia-drm
According to a moderator’s note on June 30th, this was fixed in the beta, but I ran into “Unable to load the nvidia-drm kernel module” today while installing 450.57.
I’m running the latest kernel, 5.7.8-200.fc32.x86_64.
It installed without problems when I did not choose the dkms option.
Is this a known problem, or should I reinstall and save logging info?
It loads fine here
[leigh@leigh ~]$ uname -r
5.8.0-0.rc4.1.fc33.x86_64
[leigh@leigh ~]$ lsmod |grep nvidia
nvidia_drm             57344  3
nvidia_modeset       1187840  5 nvidia_drm
nvidia_uvm           1130496  0
nvidia              19726336  193 nvidia_uvm,nvidia_modeset
drm_kms_helper        258048  1 nvidia_drm
drm                   622592  6 drm_kms_helper,nvidia_drm
[leigh@leigh ~]$
You may try downgrading dkms. Version 2.8.2, out recently, no longer builds or installs modules. See: Unable to dkms {build,install} with 2.8.2 #127. I was not able to use the installer properly until I did so.
Thanks for that. I’m not ready to move to an rc release, though.
Could you tell me what your dkms version number is?
Thanks again!
dkms --version shows “2.8” on my system; apparently, that’s incomplete.
$ sudo dnf list installed | grep dkms
dkms.noarch                                       2.8.2-1.fc32                           @updates
What version did you downgrade to?
I am also on Fedora 32 and just did:
dnf downgrade dkms (sudo, if needed)
which gave me:
Installed Packages
dkms.noarch        2.8.1-4.20200214git5ca628c.fc32        @fedora
Exactly the same problem here, but at least I know now that was to be expected, since I’m also on Fedora 32, same kernel, same dkms version.
Thank you for the post.
seeing this same problem on a number of OS/distros.
upgrades to
kernel* 5.7.9 ( not entirely sure this is/was necessary; i track kernel:stable, & picked up that update along the way)
dkms 2.8.3 (–> Release Build fixes · dell/dkms · GitHub)
cure the problem, here.
