I bought a jetson orin nano developer of 8GB I tried to flash with sd for some reason it doesn’t work then I did it connected to a PC with sdk manager and installed an M2 I manage to reach until it asks me for the ip to continue with the flashing but for some reason it doesn’t respond, but even so I manage to install ubuntu 22.04 I try to install cuda manually with success but when I try to install pytorch it tells me that it does not detect cuda. Then I try to install the jeybrek 6.2 version but on the m2 I get the same problem it reaches the IP and does not advance more but now it starts the welcome screen and then I get the black screen and it does not advance more. I try to flash with the sd but when I install it on the jetson nano to boot through the sd after the nvidia welcome I get the black screen and it does not let me continue.
Do you check your M2 formatted to ext4.
Also please run the sdk manager again and EXPORT LOGS for us to review.
Hi @giantonti1801 ,
If you are trying to install the entire JetPack 6.2 on NVMe SSD, can you follow this guide by replacing “JetPack 6.1 (rev. 1)” part with “JetPack 6.2”?
Please let us know at which step your experience diverges from what’s documented.
(for example, step 4️⃣-4, flashing fails in the process?)
