My host is a linux-ubuntu-18.04, i’ve tried several times,
I’ve connected the correct-subC port on the Xavier to the host,
During Step3 of the SDK manager (v1.3.1.7110) installing JetPack 4.4.1,
I get to this point:, about %36
16:18:06 DEBUG: Flash Jetson AGX Xavier 16GB/32GB: using adapter to install NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER to /home/kdunne/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_AGX_XAVIER
16:18:06 INFO: Flash Jetson AGX Xavier 16GB/32GB: ###############################################################################
16:08:35 INFO: Flash Jetson AGX Xavier 16GB/32GB: Error: probing the target board failed.
16:08:35 INFO: Flash Jetson AGX Xavier 16GB/32GB: Make sure the target board is connected through
16:08:35 INFO: Flash Jetson AGX Xavier 16GB/32GB: USB port and is in recovery mode.
16:08:35 INFO: Flash Jetson AGX Xavier 16GB/32GB: [ Component Install Finished with Error ]
16:08:35 INFO: Flash Jetson AGX Xavier 16GB/32GB: [host] [ 4.00 KB used. Disk Avail: 782.20 GB ]
16:08:35 INFO: Flash Jetson AGX Xavier 16GB/32GB: [ NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP Install took 6s ]
16:08:35 ERROR: Flash Jetson AGX Xavier 16GB/32GB: [error]: : [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh; [error]:
The cable and USB port are good, i’ve tested them independently, the NVIDIA dev-board appears to be connected, from DMESG:
[ 3222.261097] usb 1-5.3.3: new high-speed USB device number 13 using xhci_hcd
[ 3222.362369] usb 1-5.3.3: New USB device found, idVendor=0955, idProduct=7019, bcdDevice= 1.02
[ 3222.362374] usb 1-5.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3222.362377] usb 1-5.3.3: Product: APX
[ 3222.362379] usb 1-5.3.3: Manufacturer: NVIDIA Corp.
lsusb shows:
Bus 001 Device 011: ID 0955:7019 NVidia Corp.
