Flash Jetson OS installation error and Jetson SDK components installation error
Thanks you. I succeeded with flash. The problem was in russians symbols in path to bin with nvidia_sdk and sdk. When i was trying to flash manually - ascii error appeared - so, yes, it was it.
  1. Now i get error with multimedia api installing.
  2. I succeeded with installing other sdk components. I make all things to try CUDA samples. But i got error while trying to run CUDA samples.
CUDA error at …/…/common/inc/helper_cuda.h:775 code=35(cudaErrorInsufficientDriver) “cudaGetDevicceCount(&device_count)”
I know its a nvidia driver problem. I read Error while trying to start the examples this topic. So i cant find proper driver for agx xavier and also dont know to uninstall old driver and install proper.
