你好,我们公司之前AGX Xavier出货是用的massflash,使用nvmassflashgen.sh生成mfi_jetson-agx-xavier-devkit.tbz2,然后给到工厂,出过300台。现在改用Orin后,制作给到工厂的tar.gz文件刷机失败,我的步骤如下:
1.sudo ./flash.sh -r -k APP -G clone.img jetson-agx-orin-devkit mmcblk0p1
使用这条命令clone一块安装了我方软件的Orin核心板,得到system.img,这个system.img大小是28G
2.执行“sudo ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --massflash 5 jetson-agx-orin-devkit mmcblk0p1”后会把我28G大小的system.img替换为5G的
请问怎样才能让l4t_initrd_flash使用我安装了软件的28G大小的system.img?
hello lihl,
actually, there’s tool to backup/restore a Jetson device using the backup image.
please use the tool, /tools/backup_restore/l4t_backup_restore.sh.
for example,
there’s -b options to generate the backup image, and you could enable -r options to restore the backup image.
after you complete back-up process and have the image store to your local host,
you may read README_backup_restore.txt for the workflow to massflash the backup image.
for example,
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --use-backup-image --no-flash --massflash <x> <board-name> mmcblk0p1
Massflash package is generated successfully, thank you very much
刷机后新设备无法启动,详细描述如下:
按照<README_backup_restore.txt>中“Workflow 3: To massflash the backup image”操作,最后一步操作后(sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 5),Log中提示新设备刷机成功。但重新上电后,被刷机的新设备无法启动,现象是:Debug串口没有任何输出,跟刚买到没有刷过的Orin核心板一样。
我这要量产出货还挺着急的
请问,其他使用Orin-32G的客户量产是怎么做的?
hello lihl,
we cannot repo the failure,
please check below for our steps to backup/restore a Jetson device using the backup image…
after flash completed, device can boot up normally with backup rootfs.
$ sudo ./tools/backup_restore/l4t_backup_restore.sh -b -c jetson-agx-orin-devkit
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --use-backup-image --no-flash --massflash 1 jetson-agx-orin-devkit
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 1
使用上面的3条命令后可以成功刷机和启动了,包括“–massflash 5”,感谢您的支持
上面十月4号的帖子,我验证成功刷机和启动是用的稍微改动的system.img,大小是5G,是为了节省验证时的刷机时间.
今天用实际出货的大小是28G的system.img,刷机成功后还是启动不了,问题依然存在。具体如下:
我完全照搬上面的3条命令,刷机Log中提示刷机成功,但重启 启动不了,Debug串口没有任何log输出,刷过的Orin核心板跟没刷过的Orin核心板一样。
请问,是不是bootloader没刷进去?或者我还能再怎么尝试下?是system.img太大了,有什么地方参数不对?
hello lihl,
could you please check rootfs image size after this command-line executed?
生成的mmcblk0p1.tar.gz大小是24.3GB.
另外有个奇怪的现象:我昨天用“l4t_initrd_flash.sh --flash-only”命令分5次,每次刷一台,共刷了5台Orin核心板,都能重启能正常使用。今天同样的主机和环境,又出现刷机后不能启动的问题了,刷了2台Orin核心板刷完log提示成功,但都不能重启。懵圈了。
如果其他用户没这种刷机成功但不能启动的问题,那可能是我们PCBA的问题?我已经找了一块其他公司的Orin载板验证,要周六才能到
hello lihl,
we’ve tested it and we cannot repo the failure,
please have cross validation to confirm whether it’s hardware issue.
can you comment out these lines in tools/kernel_flash/l4t_network_flash.func
enable_nfs_for_folder ()
set +e
rpcbind > /dev/null 2>&1
set -e
local nfs_dir=$1
local networkargs=$2
local arr=
IFS=':' read -r -a arr <<< "${networkargs}"
local target_ip=${arr[1]:-fc00:1:1::/48}
chmod 755 "${nfs_dir}"
chown root.root "${nfs_dir}"
# if ! grep -qvE "^\s*#|^\s*$" /etc/exports; then
# echo "# Entry added by NVIDIA initrd flash tool" >> /etc/exports
# echo "${nfs_dir} ${target_ip}(${PERMISSION_STR})" >> /etc/exports
# fi
if [[ "${target_ip}" =~ : ]]; then
target_ip="[${target_ip}]"
fi
exportfs -o "${PERMISSION_STR}" "${target_ip}:${nfs_dir}"
and try these commands instead?
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --use-backup-image --no-flash --network usb0 --massflash 5 jetson-agx-orin-devkit mmcblk0p1
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 5 --network usb0 --showlogs
