Hi all. I’m going to flash EFM8SB10F2G on the Xavier NX custom carrier board. I use Simplicity studio 5.
However, “Invalid Argument” problem occurred.
I 've downloaded this project from jetson DLC, didn’t modify anything from the original.
When I try to reduce the code size to small, Build failed.
compile result from the Simplicity studio 5 console.
12:28:44 **** Incremental Build of configuration Keil 8051 v9.53 - Release for project EFM8SB10F2G ****
make all
PATH=/cygdrive/g/SiliconLabs/SimplicityStudio/v5/developer/toolchains/keil_8051/9.60/BIN:/cygdrive/g/SiliconLabs/SimplicityStudio/v5/support/8051:/1.0/bin:/cygdrive/g/SiliconLabs/SimplicityStudio/v5/features/com.silabs.external.java17.windows.x86_64.feature_17.0.3/jre/bin/server:/cygdrive/g/SiliconLabs/SimplicityStudio/v5/features/com.silabs.external.java17.windows.x86_64.feature_17.0.3/jre/bin:/cygdrive/g/VMware/VMware Player/bin:/cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common:/cygdrive/c/Program Files (x86)/Common Files/Oracle/Java/javapath:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64/compiler:/cygdrive/c/Windows/system32:/cygdrive/c/Windows:/cygdrive/c/Windows/System32/Wbem:/cygdrive/c/Windows/System32/WindowsPowerShell/v1.0:/cygdrive/c/Windows/System32/OpenSSH:/cygdrive/c/Program Files/Microsoft SQL Server/Client SDK/ODBC/110/Tools/Binn:/cygdrive/c/Program Files (x86)/Microsoft SQL Server/120/Tools/Binn:/cygdrive/c/Program Files/Microsoft SQL Server/120/Tools/Binn:/cygdrive/c/Program Files/Microsoft SQL Server/120/DTS/Binn:/cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit:/cygdrive/c/WINDOWS/system32:/cygdrive/c/WINDOWS:/cygdrive/c/WINDOWS/System32/Wbem:/cygdrive/c/WINDOWS/System32/WindowsPowerShell/v1.0:/cygdrive/c/WINDOWS/System32/OpenSSH:/cygdrive/c/MinGW/bin:/cygdrive/c/ProgramData/chocolatey/bin:/cygdrive/c/Program Files/IVI Foundation/VISA/Win64/bin:/cygdrive/c/Program Files (x86)/IVI Foundation/VISA/WinNT/ktvisa:/cygdrive/c/Program Files (x86)/IVI Foundation/VISA/WinNT/bin:/cygdrive/c/Program Files (x86)/IVI Foundation/VISA/WinNT/Bin:/cygdrive/c/Program Files/IVI Foundation/VISA/Win64/Bin:/cygdrive/c/Program Files (x86)/IVI Foundation/VISA/winnt/agvisa:/cygdrive/c/Program Files/NVIDIA Corporation/NVIDIA NvDLISR:/cygdrive/d/Installed_program/python_3.10.5/Scripts:/cygdrive/d/Installed_program/python_3.10.5:/cygdrive/c/Users/User/AppData/Local/Programs/Python/Python37-32/Scripts:/cygdrive/c/Users/User/AppData/Local/Programs/Python/Python37-32:/cygdrive/c/Python38-32/Scripts:/cygdrive/c/Python38-32:/cygdrive/c/Users/User/AppData/Local/Microsoft/WindowsApps:/cygdrive/c/Users/User/AppData/Local/GitHubDesktop/bin:/cygdrive/c/Users/User/AppData/Local/Programs/Microsoft VS Code/bin:/cygdrive/g/SiliconLabs/SimplicityStudio/v5
Building file: ../src/EFM8SB10F2G_main.c
Invoking: Keil 8051 Compiler
C51 "@src/EFM8SB10F2G_main.__i" || test $? -lt 2
C51 COMPILER V9.60.0.0 - SN: Eval Version
COPYRIGHT Copyright (C) 2012 - 2019 ARM Ltd and ARM Germany GmbH. All rights reserved.
C51 COMPILATION COMPLETE. 0 WARNING(S), 0 ERROR(S)
Finished building: ../src/EFM8SB10F2G_main.c
Building file: ../src/InitDevice.c
C51 "@src/InitDevice.__i" || test $? -lt 2
Finished building: ../src/InitDevice.c
Building file: ../src/Interrupts.c
C51 "@src/Interrupts.__i" || test $? -lt 2
Finished building: ../src/Interrupts.c
Building file: ../src/SILABS_STARTUP.A51
Invoking: Keil 8051 Assembler
AX51 "@src/SILABS_STARTUP.__ia" || test $? -lt 2
MACRO ASSEMBLER AX51 V3.15.3.0
COPYRIGHT ARM Germany GmbH 2016
"G:\SiliconLabs\SimplicityStudio\v5\developer\toolchains\keil_8051\9.60\BIN\AX51.exe" "D:\NVIDIA_Orin\P3737_P3768_P2822_P3509_Power_Button_Firmware_v011\EFM8SB10F2G\src\SILABS_STARTUP.A51" ERRORPRINT SET (SMALL) DEBUG MACRO NOMOD51 INCDIR(D:\NVIDIA_Orin\P3737_P3768_P2822_P3509_Power_Button_Firmware_v011\EFM8SB10F2G\inc;G:/SiliconLabs/SimplicityStudio/v5/developer/sdks/8051/v4.3.0//Device/shared/si8051Base;G:/SiliconLabs/SimplicityStudio/v5/developer/sdks/8051/v4.3.0//Device/EFM8SB1/inc) PRINT(.\src\SILABS_STARTUP.lst) COND SYMBOLS PAGEWIDTH (120) PAGELENGTH (65) OBJECT(.\src\SILABS_STARTUP.OBJ)
ASSEMBLY COMPLETE. 0 WARNING(S), 0 ERROR(S).
Finished building: ../src/SILABS_STARTUP.A51
Building file: ../src/gpio.c
C51 "@src/gpio.__i" || test $? -lt 2
Finished building: ../src/gpio.c
Building file: ../src/power.c
C51 "@src/power.__i" || test $? -lt 2
Finished building: ../src/power.c
Building target: EFM8SB10F2G.omf
Invoking: Keil 8051 Linker
LX51 "@EFM8SB10F2G.lnp" || test $? -lt 2
LX51 LINKER/LOCATER V4.66.97.0 - SN: Eval Version
COPYRIGHT ARM Germany GmbH 1995 - 2019
@EFM8SB10F2G.lnp "./src/EFM8SB10F2G_main.OBJ",
"./src/InitDevice.OBJ",
"./src/Interrupts.OBJ",
"./src/SILABS_STARTUP.OBJ",
"./src/gpio.OBJ",
"./src/power.OBJ"
TO "EFM8SB10F2G.OMF.CRBUILD" REMOVEUNUSED PRINT(.\EFM8SB10F2G.m51) PAGEWIDTH (120) PAGELENGTH (65) CLASSES( ECODE(C:0x0 - C:0x7fe), HCONST(C:0x0 - C:0x7fe), XDATA(X:0x0 - X:0x1))
*** WARNING L48: IGNORED RECURSIVE CALL
CALLED: POWEROFF/POWER
CALLER: POWERINGOFF/POWER
CALLED: POWERON/POWER
CALLER: RESET/POWER
*** ERROR L121: IMPROPER FIXUP
MODULE: ./src/Interrupts.OBJ (INTERRUPTS)
SEGMENT: ?INTERRUPTS?0002B
OFFSET: 00002BH
SEGMENT: ?PR?TIMER2_ISR?INTERRUPTS
OFFSET: 0000C9H
* RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 0527H BYTE (64%) *
Program Size: data=25.0 xdata=0 const=15 code=1463
LX51 RUN COMPLETE. 2 WARNING(S), 2 ERROR(S)
make: *** [makefile:45: EFM8SB10F2G.omf] Error 1
"make all" terminated with exit code 2. Build might be incomplete.
12:28:46 Build Failed. 3 errors, 2 warnings. (took 1s.440ms)
This is my post at SiLabs community.
