Jetson Xavier NX :Can you provide EFM8SB10F2G(MCU) function flow chart?Thanks!
This topic should have been posted in the Jetson forums, moving it now.
Hi, there is no such info can be provided. For this button MCU, please refer to below description in DG.
The Developer Kit carrier board implements a button power MCU (EFM8SB10F2G). This device is programmed with firmware that is available on the Jetson Download Center. The posting is titled “Jetson AGX Xavier and Jetson Xavier NX Power Button Supervisor Firmware.” The connections used on the reference design must be followed exactly and the firmware provided must be used to ensure correct functionality.
