short circuit on this chip and the temperature is very high after power on, I would like to know its model in order to fix it
Thanks,
Thanks,
It’s button MCU EFM8SB10F2G.
Thanks, but does that mean I still need to flash firmware to fix it. Can I get the relevant documents?
Please refer to below info in Design Guide:
3.1 Button Power MCU
The Developer Kit carrier board implements a button power MCU (EFM8SB10F2G). This device is programmed with firmware that is available on the Jetson Download Center. The posting is titled “Jetson AGX Xavier and Jetson Xavier NX Power Button Supervisor Firmware.” The connections used on the reference design must be followed exactly and the firmware provided must be used to ensure correct functionality
