This is a report against r35.3.1, which is a little older. I also reported it against r32.7.2 a few years ago but it was reported as fixed, which doesn’t appear to be the case.
I have built a custom rootfs outside of the Linux_for_Tegra directory. I am running flash.sh -R /path/to/actual_rootfs/ ...to specify the absolute path to this directory.
Occasionally the flash.sh tries to read files from Linux_for_Tegra/rootfs, which is the wrong rootfs. These issues can be found by removing Linux_for_Tegra/rootfs and attempting the flashing process. If the scripts correctly abide by the -R option, there will be no errors.
The
flash.shscript tries to access${LDK_DIR}/rootfs/etc/nv_tegra_releaseand${LDK_DIR}/rootfs/etc/user_release_version. -
The
ota_make_recovery_img_dtb.shscript is invoked where it is hardcoded forlocal _rootfs_dir="${_ldk_dir}/rootfs".
The consequence of these issues is that you end up with an inconsistently flashed product depending on where your rootfs is stored.
The workaround is to rm -Rf Linux_for_Tegra/rootfs && ln -s /path/to/actual_rootfs/ Linux_for_Tegra/rootfs.
