Flashing Failed
Hello, I am using the Xavier A203 carrier board and I encounter no issues when flashing version 5.0.2 of BSV. However, I get a “flashing failed” error when trying to flash version 4.6. I will share the log files below. Thank you for your help.
SDKM_logs_JetPack_4.6_(rev._3)_Linux_for_Jetson_Xavier_NX_modules_2024-08-04_18-24-02.zip (46.6 KB)
please flash with latest jetapck4 instead of jetpack4.6.
It supports BSP version 4.6. Will this cause any issues?
I have one more problem. I installed 5.0.2 version retry and i tried install CUDA other SDK Components, but there is not enough disk space in Xavier. But i have 64 GB SDcard in Xavier and i seeing disk. Can i use SDcard like main storage
As I already explained in your previous post.
You are not using NVIDIA developer kit but a custom carrier board from other vendor.
You need to contact that board vendor for their firmware.
No software from NV will enable that sdcard slot on your board.
