hi,Failed flashing Jetson AGX Xavier,using sudo ./flash.sh jetson-agx-xavier-devkit mmcblk0p1
Please help me.
Flash_log.txt (61.6 KB)
Please help me.
Please Download NVIDIA SDK Manager
Follow the steps at Install Jetson Software with SDK Manager.
Please be sure to have a host PC with Ubuntu 20.04 to install it, then can use the include JetPack 5.0.2 GA to reflash your Jetson AGX Xavier devkit.
Both SDK Manager and flash.sh failed,Only this one failed
I used the same method to reflash other AGX successfully。
SDKManager_log.txt (5.3 KB)
SDKM_logs_JetPack_4.6.2_Linux_for_Jetson_AGX_Xavier_2022-08-26_15-18-40.zip (232.5 KB)
So this could be HW issue if can’t be reflashed, you may try to do the RMA, see Jetson FAQ | NVIDIA Developer
are you using SDK manager and using virtual box to host your source system? if yes, I need to switch to use vmware to get the flash work
Yes,I used vmware to complete the above work
