I am currently stuck trying to flash my Orin NX 16GB running it through a VMWare Workstation Player Pro 17 using Ubuntu 20.04 for Yahboom carrier on a 256GB Flash Drive. I am currently running out of ideas as I have tried reflashing the Jetson Orin NX with Jetpack 6, 5.1.3, 5.1.2, 5.1.1 and installation is all failing at 95.5%. Every time I tried to flash a new Jetpack version, I had to take out the SSD Card from the Jetson Orin , delete all the partitions and create one new partition.
My goal is to achieve the following successfully:
Steps to flash:
Remove All partitions
Create a new partition Using Disk Genius
Put SSD into Jetson Orin NX
Flash Jetpack using SDK Manager
Remove SSD Again
Use Win32DiskImager to burn Robot image into that partition
Expand the image to use unallocated space using Disk Genius
Plug the SSD back into the Jetson Orin NX 16GB
Any guidance would be much appreciated as I have spent well over two weeks on this matter.
Any recommendations for me if you have had experience flashing Jetson Orin NX 16GB with these robots and they use a specific Ubuntu version of 20.04 ?
I will try to use a Ubuntu OS host but it has Ubuntu version 22.04, do you think that will work out if I flash the Jetson Nano Orin NX using Ubuntu 22.04? or will I have to downgrade the host to 20.04?
Sorry for asking so many questions and thanks for the help so far
Would a bootable USB also work for the Ubuntu OS host? would dual booting work as well? or would I have to set the main operating system as Ubuntu for the host?
I am also wondering when it comes to the flashing process, do we have to remove the FC REC jumper cable during flashing?
Where can I find the exact steps I need to follow for flashing Jetson Orin NX 16GB
