Hi, I am using Flint tool with ConnectX-7 to upgrade the firmware of the inserted cable, However, the
command “flint -d 01:00.0_cable_0 --activate --activate_delay_sec 10 b” did not actually delay the FW image activating process. Is there other flag should be used to add delay for activating the FW image? Thanks
Hi Howard,
When you burn cable fw, you need reseat or up/dn the port to make it work.
So I think this delay is not important.
I never test this option, if you want know it better, you can open a SF ticket to follow it.
Thanks,
Suo
