Hello, I;m a new Xavier NX user and installed jetpack4.4 and opencv 3.4 at /usr/local
Also I installed some package which required opencv lib exactly “highgui”.
However whenever i try to make It is not found although it is already installed,
So i tried “sudo apt install libopencv*” and i got
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libopencv-dev : Conflicts: libopencv-calib3d-dev
Conflicts: libopencv-core-dev
Conflicts: libopencv-features2d-dev
Conflicts: libopencv-flann-dev
Conflicts: libopencv-highgui-dev
Conflicts: libopencv-imgcodecs-dev
Conflicts: libopencv-imgproc-dev
Conflicts: libopencv-ml-dev
Conflicts: libopencv-objdetect-dev
Conflicts: libopencv-photo-dev
Conflicts: libopencv-stitching-dev
Conflicts: libopencv-ts-dev
Conflicts: libopencv-video-dev
Conflicts: libopencv-videoio-dev
E: Unable to correct problems, you have held broken packages.
How can I treat it?? Please let me know …
