We are making xavier nx fanless cases.
The temperature (Celsius) of the spec sheet ranges from -20 degrees Celsius to -90 degrees Celsius.
In case of fanless use, to what temperature do you ensure trouble-free operation?
Thank you.
Thank you.
It is the range of “trouble-free operation” no matter fan or fanless.
If you have tested something internally
To what temperature does it work without failure?
Thank you.
Please refer to the reliability list table in module datasheet in DLC: Jetson Download Center | NVIDIA Developer
