I am passing MIPI csi stream from an image sensor through a FPGA to the TX1:
Imager->FPGA->TX1
Camera I2C Interface is directly connected to TX1.
Running nvgstcapture/argus_camera application freezes linux system.
Here is part of the log-file after running the applications:
[ 60.487560] fence timeout on [ffffffc024bfb800] after 1500ms
[ 60.493224] name=[nvhost_sync:7], current value=0 waiting value=1
[ 60.499374] fence timeout on [ffffffc024bfb300] after 1500ms
[ 60.499598] fence timeout on [ffffffc0225cac00] after 1500ms
[ 60.499602] name=[nvhost_sync:29], current value=1 waiting value=2
[ 60.499606] ---- mlocks ----
[ 60.499616]
[ 60.499618] ---- syncpts ----
[ 60.499623] id 1 (disp1_a) min 159 max 159 refs 1 (previous client : )
[ 60.499626] id 2 (disp1_b) min 1 max 1 refs 1 (previous client : )
[ 60.499629] id 3 (disp1_c) min 1 max 1 refs 1 (previous client : )
[ 60.499632] id 4 (57000000.gpu_507) min 6708 max 6708 refs 1 (previous client : )
[ 60.499635] id 5 (57000000.gpu_506) min 26 max 26 refs 1 (previous client : )
[ 60.499638] id 6 (57000000.gpu_505) min 838 max 838 refs 1 (previous client : 57000000.gpu_505)
[ 60.499641] id 7 (54600000.isp_0) min 0 max 3 refs 4 (previous client : )
[ 60.499644] id 8 (54600000.isp_1) min 0 max 3 refs 4 (previous client : )
[ 60.499646] id 9 (54600000.isp_2) min 7 max 16 refs 11 (previous client : )
[ 60.499650] id 11 (54600000.isp_3) min 1 max 3 refs 4 (previous client : )
[ 60.499655] id 16 (57000000.gpu_504) min 1222 max 1222 refs 1 (previous client : )
[ 60.499658] id 17 (57000000.gpu_503) min 2 max 2 refs 1 (previous client : )
[ 60.499661] id 18 (57000000.gpu_502) min 2 max 2 refs 1 (previous client : )
[ 60.499663] id 19 (57000000.gpu_501) min 2 max 2 refs 1 (previous client : )
[ 60.499666] id 20 (57000000.gpu_500) min 2 max 2 refs 1 (previous client : )
[ 60.499669] id 21 (57000000.gpu_499) min 8 max 8 refs 1 (previous client : )
[ 60.499672] id 22 (54080000.vi_0) min 0 max 3 refs 4 (previous client : 54080000.vi_0)
[ 60.499675] id 24 (54080000.vi_2) min 2 max 7 refs 7 (previous client : 54080000.vi_2)
[ 60.499679] id 27 (vblank1) min 3421 max 0 refs 1 (previous client : )
[ 60.499683] id 29 (54080000.vi_4) min 1 max 3 refs 4 (previous client : 54080000.vi_4)
[ 60.499688] id 34 (57000000.gpu_498) min 1060 max 1060 refs 1 (previous client : )
[ 60.499691] id 35 (57000000.gpu_497) min 2 max 2 refs 1 (previous client : )
[ 60.499694] id 36 (57000000.gpu_496) min 2 max 2 refs 1 (previous client : )
[ 60.499696] id 37 (57000000.gpu_495) min 2 max 2 refs 1 (previous client : )
[ 60.499699] id 38 (57000000.gpu_494) min 2 max 2 refs 1 (previous client : )
[ 60.499702] id 39 (57000000.gpu_493) min 4 max 4 refs 1 (previous client : )
[ 60.499705] id 40 (57000000.gpu_492) min 6 max 6 refs 1 (previous client : )
[ 60.499708] id 41 (57000000.gpu_491) min 8 max 8 refs 1 (previous client : )
[ 60.499710] id 42 (57000000.gpu_490) min 6 max 6 refs 1 (previous client : )
[ 60.499713] id 43 (57000000.gpu_489) min 6 max 6 refs 1 (previous client : )
[ 60.499716] id 44 (57000000.gpu_488) min 6 max 6 refs 1 (previous client : )
[ 60.499718] id 45 (57000000.gpu_487) min 6 max 6 refs 1 (previous client : )
[ 60.499721] id 46 (57000000.gpu_486) min 6 max 6 refs 1 (previous client : )
[ 60.499816]
[ 60.499816] ---- channels ----
[ 60.499822]
[ 60.499822] channel 0 - 54600000.isp
[ 60.499822]
[ 60.499830] 0-54600000.isp (19): active class 01, offset 0050, val 00000007
[ 60.499832] DMAPUT 000001b0, DMAGET 000000e8, DMACTL 00000000
[ 60.499833] CBREAD 00000007, CBSTAT 00010050
[ 60.499837]
[ 60.499837] ffffffc023b2ca00: JOB, syncpt_id=7, syncpt_val=1, first_get=00000090, timeout=10000, num_slots=3, num_handles=1
[ 60.499845] GATHER at 80270000+4514, 8 words
[ 60.499853] 20000001 00000407 20000001 00000508 20000001 0000060b 200c0001 00000005
[ 60.499856] GATHER at 80270000+4534, 2 words
[ 60.499858] 20000001 00000009
[ 60.499859]
[ 60.499862]
[ 60.499862] channel 1 - 54680000.isp
[ 60.499862]
[ 60.499867] 1-54680000.isp (1): inactive
[ 60.499867]
[ 60.499869]
[ 60.499869] channel 2 - 54080000.vi
[ 60.499869]
[ 60.499876] 2-54080000.vi (12): active class 01, offset 0050, val 00000016
[ 60.499878] DMAPUT 00000100, DMAGET 00000100, DMACTL 00000000
[ 60.499879] CBREAD 00000016, CBSTAT 00010050
[ 60.499882]
[ 60.499882] ffffffc0d4eeb000: JOB, syncpt_id=22, syncpt_val=1, first_get=00000018, timeout=10000, num_slots=7, num_handles=1
[ 60.499886] GATHER at 802e0000+0000, 39 words
[ 60.499920] 10620001 0000001f 10630002 00000000 00000000 103a0001 10100010 103c0001 10101010 10420001 00000001 10430006 00000000 001c984c 00000000 00000000 00000000 00000000 10590001 00000003 120e0006 007f0017 080301f0 00000000 00140000 0000f005 00000000 12420001 0000
[ 60.499922] GATHER at 802e0000+009c, 3 words
[ 60.499925] 304e0005 00000007 00000009
[ 60.499927] GATHER at 802e0000+00a8, 21 words
[ 60.499946] 10430006 00200002 001c984c 00000000 087e0f18 000012de 0000002b 124b0003 00010000 00000000 00000007 12580003 00010000 00000000 00000007 20000001 00001c16 20000001 0000051d 20410001 00000001
[ 60.499948] GATHER at 802e0000+00fc, 2 words
[ 60.499950] 20000001 00000018
[ 60.499951]
[ 60.499952]
[ 60.499952] ---- host general irq ----
[ 60.499952]
[ 60.499954] sync_hintmask_ext = 0xc0000000
[ 60.499956] sync_hintmask = 0x80000000
[ 60.499958] sync_intc0mask = 0x00000001
[ 60.499959] sync_intmask = 0x00000011
[ 60.499960]
[ 60.499960] ---- host syncpt irq mask ----
[ 60.499960]
[ 60.499962] syncpt_thresh_int_mask(0) = 0x00454001
[ 60.499964] syncpt_thresh_int_mask(1) = 0x04011000
[ 60.499966] syncpt_thresh_int_mask(2) = 0x00000000
[ 60.499968] syncpt_thresh_int_mask(3) = 0x00000000
[ 60.499970] syncpt_thresh_int_mask(4) = 0x00000000
[ 60.499971] syncpt_thresh_int_mask(5) = 0x00000000
[ 60.499973] syncpt_thresh_int_mask(6) = 0x00000000
[ 60.499975] syncpt_thresh_int_mask(7) = 0x00000000
[ 60.499976] syncpt_thresh_int_mask(8) = 0x00000000
[ 60.499978] syncpt_thresh_int_mask(9) = 0x00000000
[ 60.499980] syncpt_thresh_int_mask(10) = 0x00000000
[ 60.499982] syncpt_thresh_int_mask(11) = 0x00000000
[ 60.499983]
[ 60.499983] ---- host syncpt irq status ----
[ 60.499983]
[ 60.499985] syncpt_thresh_cpu0_int_status(0) = 0x00000800
[ 60.499986] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 60.499988] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 60.499990] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 60.499992] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 60.499993] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 60.499994]
[ 60.499994] ---- host syncpt thresh ----
[ 60.499994]
[ 60.499997] syncpt_int_thresh_thresh_0(0) = 1
[ 60.500002] syncpt_int_thresh_thresh_0(7) = 1
[ 60.500005] syncpt_int_thresh_thresh_0(8) = 1
[ 60.500007] syncpt_int_thresh_thresh_0(9) = 8
[ 60.500010] syncpt_int_thresh_thresh_0(11) = 1
[ 60.500018] syncpt_int_thresh_thresh_0(22) = 1
[ 60.500021] syncpt_int_thresh_thresh_0(24) = 3
[ 60.500025] syncpt_int_thresh_thresh_0(29) = 2
[ 60.505656] ---- mlocks ----
[ 60.505667]
[ 60.505669] ---- syncpts ----
[ 60.505675] id 1 (disp1_a) min 159 max 159 refs 1 (previous client : )
[ 60.505678] id 2 (disp1_b) min 1 max 1 refs 1 (previous client : )
[ 60.505681] id 3 (disp1_c) min 1 max 1 refs 1 (previous client : )
[ 60.505684] id 4 (57000000.gpu_507) min 6708 max 6708 refs 1 (previous client : )
[ 60.505687] id 5 (57000000.gpu_506) min 26 max 26 refs 1 (previous client : )
[ 60.505690] id 6 (57000000.gpu_505) min 838 max 838 refs 1 (previous client : 57000000.gpu_505)
[ 60.505693] id 7 (54600000.isp_0) min 0 max 4 refs 5 (previous client : )
[ 60.505695] id 8 (54600000.isp_1) min 0 max 4 refs 5 (previous client : )
[ 60.505698] id 9 (54600000.isp_2) min 7 max 20 refs 15 (previous client : )
[ 60.505701] id 11 (54600000.isp_3) min 1 max 4 refs 5 (previous client : )
[ 60.505707] id 16 (57000000.gpu_504) min 1222 max 1222 refs 1 (previous client : )
[ 60.505710] id 17 (57000000.gpu_503) min 2 max 2 refs 1 (previous client : )
[ 60.505712] id 18 (57000000.gpu_502) min 2 max 2 refs 1 (previous client : )
[ 60.505715] id 19 (57000000.gpu_501) min 2 max 2 refs 1 (previous client : )
[ 60.505718] id 20 (57000000.gpu_500) min 2 max 2 refs 1 (previous client : )
[ 60.505720] id 21 (57000000.gpu_499) min 8 max 8 refs 1 (previous client : )
[ 60.505723] id 22 (54080000.vi_0) min 0 max 4 refs 5 (previous client : 54080000.vi_0)
[ 60.505727] id 24 (54080000.vi_2) min 2 max 9 refs 9 (previous client : 54080000.vi_2)
[ 60.505732] id 27 (vblank1) min 3421 max 0 refs 1 (previous client : )
[ 60.505735] id 29 (54080000.vi_4) min 1 max 4 refs 5 (previous client : 54080000.vi_4)
[ 60.505741] id 34 (57000000.gpu_498) min 1060 max 1060 refs 1 (previous client : )
[ 60.505743] id 35 (57000000.gpu_497) min 2 max 2 refs 1 (previous client : )
[ 60.505748] id 36 (57000000.gpu_496) min 2 max 2 refs 1 (previous client : )
[ 60.505751] id 37 (57000000.gpu_495) min 2 max 2 refs 1 (previous client : )
[ 60.505753] id 38 (57000000.gpu_494) min 2 max 2 refs 1 (previous client : )
[ 60.505756] id 39 (57000000.gpu_493) min 4 max 4 refs 1 (previous client : )
[ 60.505759] id 40 (57000000.gpu_492) min 6 max 6 refs 1 (previous client : )
[ 60.505761] id 41 (57000000.gpu_491) min 8 max 8 refs 1 (previous client : )
[ 60.505764] id 42 (57000000.gpu_490) min 6 max 6 refs 1 (previous client : )
[ 60.505767] id 43 (57000000.gpu_489) min 6 max 6 refs 1 (previous client : )
[ 60.505770] id 44 (57000000.gpu_488) min 6 max 6 refs 1 (previous client : )
[ 60.505772] id 45 (57000000.gpu_487) min 6 max 6 refs 1 (previous client : )
[ 60.505775] id 46 (57000000.gpu_486) min 6 max 6 refs 1 (previous client : )
[ 60.505869]
[ 60.505870] ---- channels ----
[ 60.505875]
[ 60.505875] channel 0 - 54600000.isp
[ 60.505875]
[ 60.505883] 0-54600000.isp (26): active class 01, offset 0050, val 00000007
[ 60.505885] DMAPUT 00000220, DMAGET 000000e8, DMACTL 00000000
[ 60.505886] CBREAD 00000007, CBSTAT 00010050
[ 60.505891]
[ 60.505891] ffffffc023b2ca00: JOB, syncpt_id=7, syncpt_val=1, first_get=00000090, timeout=10000, num_slots=3, num_handles=1
[ 60.505894] GATHER at 80270000+4514, 8 words
[ 60.505903] 20000001 00000407 20000001 00000508 20000001 0000060b 200c0001 00000005
[ 60.505905] GATHER at 80270000+4534, 2 words
[ 60.505908] 20000001 00000009
[ 60.505909]
[ 60.505911]
[ 60.505911] channel 1 - 54680000.isp
[ 60.505911]
[ 60.505917] 1-54680000.isp (1): inactive
[ 60.505917]
[ 60.505949]
[ 60.505949] channel 2 - 54080000.vi
[ 60.505949]
[ 60.505957] 2-54080000.vi (16): active class 01, offset 0050, val 00000016
[ 60.505958] DMAPUT 00000148, DMAGET 00000110, DMACTL 00000000
[ 60.505960] CBREAD 00000016, CBSTAT 00010050
[ 60.505963]
[ 60.505963] ffffffc0d4eeb000: JOB, syncpt_id=22, syncpt_val=1, first_get=00000018, timeout=10000, num_slots=7, num_handles=1
[ 60.505965] GATHER at 802e0000+0000, 39 words
[ 60.506003] 10620001 0000001f 10630002 00000000 00000000 103a0001 10100010 103c0001 10101010 10420001 00000001 10430006 00000000 001c984c 00000000 00000000 00000000 00000000 10590001 00000003 120e0006 007f0017 080301f0 00000000 00140000 0000f005 00000000 12420001 0000
[ 60.506005] GATHER at 802e0000+009c, 3 words
[ 60.506008] 304e0005 00000007 00000009
[ 60.506010] GATHER at 802e0000+00a8, 21 words
[ 60.506030] 10430006 00200002 001c984c 00000000 087e0f18 000012de 0000002b 124b0003 00010000 00000000 00000007 12580003 00010000 00000000 00000007 20000001 00001c16 20000001 0000051d 20410001 00000001
[ 60.506032] GATHER at 802e0000+00fc, 2 words
[ 60.506035] 20000001 00000018
[ 60.506036]
[ 60.506037]
[ 60.506037] ---- host general irq ----
[ 60.506037]
[ 60.506039] sync_hintmask_ext = 0xc0000000
[ 60.506041] sync_hintmask = 0x80000000
[ 60.506043] sync_intc0mask = 0x00000001
[ 60.506045] sync_intmask = 0x00000011
[ 60.506046]
[ 60.506046] ---- host syncpt irq mask ----
[ 60.506046]
[ 60.506048] syncpt_thresh_int_mask(0) = 0x00454001
[ 60.506050] syncpt_thresh_int_mask(1) = 0x04011000
[ 60.506052] syncpt_thresh_int_mask(2) = 0x00000000
[ 60.506053] syncpt_thresh_int_mask(3) = 0x00000000
[ 60.506055] syncpt_thresh_int_mask(4) = 0x00000000
[ 60.506057] syncpt_thresh_int_mask(5) = 0x00000000
[ 60.506059] syncpt_thresh_int_mask(6) = 0x00000000
[ 60.506061] syncpt_thresh_int_mask(7) = 0x00000000
[ 60.506063] syncpt_thresh_int_mask(8) = 0x00000000
[ 60.506064] syncpt_thresh_int_mask(9) = 0x00000000
[ 60.506066] syncpt_thresh_int_mask(10) = 0x00000000
[ 60.506068] syncpt_thresh_int_mask(11) = 0x00000000
[ 60.506069]
[ 60.506069] ---- host syncpt irq status ----
[ 60.506069]
[ 60.506071] syncpt_thresh_cpu0_int_status(0) = 0x00000800
[ 60.506073] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 60.506075] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 60.506076] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 60.506078] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 60.506080] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 60.506082]
[ 60.506082] ---- host syncpt thresh ----
[ 60.506082]
[ 60.506084] syncpt_int_thresh_thresh_0(0) = 1
[ 60.506090] syncpt_int_thresh_thresh_0(7) = 1
[ 60.506092] syncpt_int_thresh_thresh_0(8) = 1
[ 60.506095] syncpt_int_thresh_thresh_0(9) = 8
[ 60.506098] syncpt_int_thresh_thresh_0(11) = 1
[ 60.506105] syncpt_int_thresh_thresh_0(22) = 1
[ 60.506108] syncpt_int_thresh_thresh_0(24) = 3
[ 60.506113] syncpt_int_thresh_thresh_0(29) = 2
[ 61.709630] tegra-i2c 7000d000.i2c: pio xfer timed out addr: 0x3c
[ 61.711473] name=[nvhost_sync:8], current value=0 waiting value=1
[ 61.711476] ---- mlocks ----
The log is not helpful. How to get more info?
But running v4l2-ctl --stream-mmap=3 frames are being continously recognized @ 60fps.
