Frame generation is broken and some other issues - Indiana Jones and the Great Circle
I’m not sure if this is a game issue or a driver issue, but basically, Indiana Jones and the Great Circle has an issue where frame generation does nothing. It turns on, but the frame rate doesn’t change.
there is no option for fullscreen.
Game seems to be locked to 60 fps when path tracing is turned on?
posting on reddit about this shows that others have the same problem.
let me know if you want any other information, thanks for any ideas or help
drivers are on 566.36 after a PC reset
Asus 4070 super oc
5600x
64gb ram
game is on an m.2 ssd
Welcome to the NVIDIA Developer forums. This community serves the developer ecosystem.
For consumer issues, please visit the GeForce forums.
https://www.nvidia.com/en-us/geforce/forums/geforce-graphics-cards/5/
Best regards.
Same problem here with a 4080
The solution is to disable HDR in-game and use Windows 11’s own AutoHDR instead. Check out this thread I found for more info.
For the lazy/ADHD: Turn off Low Latency in the 3D settings of the Nvidia Control Panel as well. If you’re like me and play twitch shooters, then you can always set low latency on a per-game basis. Once in-game HDR and Nvidia Low Latency are turned off, Frame Gen will start working.
BTW, if AutoHDR isn’t working for you, you can force enable it by running this tool and typing in the game path when prompted. If that tool doesn’t work for you, try this one and restart your PC after applying the patch.
To confirm that the patched worked, launch the game and then press WinKey+G. Click the Settings cog at the top, go to the “Gaming features” tab, and then increase the “HDR Intensity” slider to your liking to confirm that it is working.
Hope this helps at least one person.
